- 2013 G37x 7AT
- 5at Compatibility
- infiniti g37x sedan 2012 VVEL MODULE CONTROL REPLACEMENT
- Clutch feels "lose"
- faint whistle noise @ 75mph+
- Infiniti G37x sedan 2012 code P1091
- Review K&n air filter cleaning
- Issue after ITB13-019a
- Manual shift knob on automatic g37
- Help FML, I have the dreaded P0524 and P0021. What should I do next?
- What could cause the RPM to bog down only around 1k?
- Coolant Hose Clamp Questions
- When to change transmission fluid?
- 2013 G 37 S Error Code p2096
- Help Weird loss of power
- Help Infiniti G37x 2013 Limp mode?
- Weird Sound Help
- Help Slipping in 2nd & 5th
- Help 7AT acting strange after car was in body shop for seven weeks
- Help Gtm stage 2 twin turbo g37
- Oil pan drain plug stripped?
- Why are paddle shifters cheaper from the dealership than ebay?
- 2012 infiniti G37xS Coupe issues?
- S. F. bay area, looking for places that reprogram the ECU
- Help with Overheating
- Help Changing Power Steering Pump
- Coolant line question
- HELP!! I misshifted 4th to 3rd!!!!
- engine temp
- Engine swap
- how to turn off Check Engine ???
- Need advice: 09 g37x leaking galley gaskets
- NEED HELP! Nissan Couldn’t Fix it...
- ses engine steady on- maf code
- Clutch Position Switch
- Shifting Gear 1->2 as RPM decreases
- Knocking noise and low oil pressure after changing head gasket
- Possible starter issue
- NEW INFINITI owner need transmission help
- Slip into neutral????
- 2009 g37x First gas vehicle I've ever owned and could use some pointers.
- Please help me
- Overfilling engine oil?
- G37 TB Green Inside
- Need your opinions on 6 speed
- P0300 can anyone help
- G37x 7at humming/vibration only at 65mph
- Hp questions
- Notify the Attorney Generals office and BBB
- 08 Infiniti G37s 6 mt not sure if its a clutch or electrical problem.
- Help 350z vs G37 stub axle swap
- P1090 code, anyone know what's going on?
- 2010 G37x whine/dull clicking at >30 mph
- Vehicle storage questions
- Blown diff bushing
- Help O2 sensor help
- Question about differentials/transfer case fluids:
- Best Tune?
- installing VLSD - is this a problem?
- Anyone ever done a DIY Supercharger install? (NO KIT)
- 2009 g37 sedán limp mode!!??
- Engine Continuum Fuse Keeps Blowing
- Clutch loses pressure overnight
- 2011 G37 over heating issue
- High mileage transmission fluid change?
- 7 Speed Auto Transmission - Coasting Status??
- Stillen SC Belt wear
- Help permanent error codes
- 2011 engine in 2008 g37s ?
- Help falling engine speed
- Still using Nissan Ester Oil?
- 2012 g37 not push to start
- Engine oil
- Help car transmission slipping/ cant shift past 1st gear
- Is FI realistic for 7AT AWD models?
- Automatic transmission issue/lock up Reply
- Coolant leak?
- Swapping a VQ25HR engine with a VQ37VHR
- Help with flex disk driveshaft coupler guibo
- Problems after Throttle Body cleaning
- Is my dealership is dishonest?. Another transmission service.
- Bad idle???
- 2009 Coupe Clutch Clunk
- To change fluids or not
- Rear differential change
- Pulled the #6 plug
- Parking brake (leg brake) turns on when accelerating
- Stillen Kit + ART pipes + TS BPV
- AWD click/pop while reversing and quick question
- CV Axles
- Jolt when shifting into Reverse
- G37 Overheating issue
- Feels like it starts in 2nd gear
- 09 g37x rough idle
- Mishimoto G37 Direct Fit Catch Can Thread
- Just bought my g37s 6MT yesterday and No Throttle?!?
- Stillen Supercharger MAF relocation, Tial BOV
- Oil filter mess Maybe it's just me? You know a better way?
- Question about camshaft position sensor
- Help G37 engine in g25
