PDA
View Full Version : Engine, Drivetrain & Forced-Induction
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 [61] 62
  1. Burning smell when I gas hard
  2. G37S VVEL Twin Turbo, 4.5L Stroker... DYNO INSIDE AS WELL
  3. Trans talk....
  4. Anyway to keep the VDC OFF????
  5. Creaking Noise coming from rear tires
  6. Engine Cover Painted!!!
  7. 2200 miles and already have a "Service Engine Soon" light
  8. Cant stand the clutch pedal
  9. Does your 6MT shifter rattles at high rpms?
  10. So what's the general consensus on breaking in our cars?
  11. Rev limiter 4000 RPM when neutral?
  12. G37 performance chip...
  13. GAS is getting a lot better in my G37
  14. Gas
  15. Engine questions before I buy
  16. RPM at a 70 MPH - 6MT only
  17. tiptronic
  18. Service Engine Soon Light
  19. Intake & Exhaust before break in, or wait?
  20. Is this chip any good?
  21. Clutch sounds like a diesel
  22. Services/Maintenance
  23. ECU Reset
  24. Service Call: Chatter,clutch click,chirp
  25. Almost Redline :-(
  26. oilchange
  27. really hard gear change from 2nd to 3rd (automatic transmission)
  28. What is up with the ECU??
  29. 13-15 Mpg?
  30. What do about this product?
  31. 1200 miles and already experiencing problems
  32. Something weird happens when the gas is low
  33. just a question???
  34. First 3000 miles?
  35. Any word on engine upgrades for the G37 ?
  36. Can Someone Post a D.I.Y. Oil Change for G37
  37. Dyno'd my G37S
  38. 2008 G37S Acceleration Lag
  39. GAS-Regular or premium? and GUMOUT-good or bad?
  40. Cold start up's. What do you guys think?
  41. Bolt-on Turbo Kit, Supercharger, and OEM
  42. Where can i get some FI???
  43. Modified Mag Write Up On NA parts!!!
  44. Hard shift from 2nd to 3rd gear
  45. launching a 5AT
  46. Super charged G37.....
  47. What speeds do u all paddle shift at in 5AT?
  48. Unknown sound coming from engine?
  49. Quick Gas question
  50. AWD Drivetrain
  51. Clutch Click
  52. kickin out the read end -bad for differential?
  53. Free Alignment from Infiniti
  54. dumb but may be posible?
  55. Reset "service engine soon" light?
  56. Oil change/Fujita Intakes/warrenty
  57. Sport mode
  58. G37's adaptive cruise reviewed
  59. Name that noise
  60. Rattle coming from the engine.
  61. Do not use the Infiniti supplied fuse puller
  62. Finally the GTMotorsport Twin is available
  63. problem with the engine i think...
  64. direct port No2
  65. Nitrous.
  66. Wheel Hop
  67. service engine light
  68. No Motordyne Products for G37???
  69. Power Steering Fluid
  70. 1st problem - had to take it in for service
  71. Block heater?
  72. Can u all teach me how to paddle shift my G37S?
  73. 10 Best Engines of 2007
  74. G37 Tiptronic?
  75. Guy question on 6mt
  76. How durable is the transmission?
  77. how to reset ECU w/out disconnecting battery?
  78. Rough downshift in 5AT
  79. How come G37 torque is low?
  80. Car won't let me pump gas
  81. First Oil Change
  82. Tchnosquare reflash for the VQ35HR...
  83. Is this normal? Or a bad sign
  84. Variable Steering Ratio
  85. A Word From Cobb Tuning...
  86. future upgrades
  87. Dead Battery
  88. SC or Turbo?
  89. controvertial topic
  90. Mobil One?
  91. RPMs
  92. How many miles till your first oil change?
  93. AT Downshift Problem
  94. AT compared to BMW 3 series?
  95. Weak Clutch?
  96. When does the G37 get some mild cams?
  97. G37s dyno report
  98. Cold start noise
  99. g37 power question
  100. Did My First Oil Change Today
