PDA
View Full Version : Engine, Drivetrain & Forced-Induction
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 [32] 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62
  1. Planning on supercharging G coupe: go G37S or G37X?
  2. max horsepower potential of stillen supercharger
  3. intermittent limp mode
  4. G37x Coupe horrible mpg??
  5. Throttle Bodies .. Not opening in full !
  6. Ebay Test Pipe Questions...
  7. Question about exhausts
  8. Review UpRev Tune
  9. transmission update ITB12-075 vs ITB12-07
  10. HELP need mid section for stillen cat back
  11. ***Dyno Kings***Grand Opening March 5, 2014***Details in Thread
  12. 2011 IPL Clutch got stuck
  13. g37 clutch
  14. Yay or nay on Lucas fuel injector cleaner
  15. Anyone has the Z1 intake plenum mod?
  16. Idle knocking/tapping noise
  17. M370 and Uprev Tune question
  18. Stillen High Boost Pulley
  19. G37x Engine Brackets HELP!!
  20. Limp Mode, Code P0021. Dealership wants $2650
  21. NA Power Mods Worhtless?
  22. Help Transmission or Engine Issue
  23. Help Zspeed CSC throw out bearing question
  24. Car Not Starting, cranks long and hard, sputters, but never turns on
  25. VLSD vs Quaife
  26. smoke or steam???
  27. Car revving while stopped
  28. Help P0021 and P0524??
  29. New Clutch engaging late in the pedal travel
  30. First Service Engine Light and Code
  31. Q50 vs G37
  32. GTMs GTR Intake Manifold Mod
  33. Review This Morning At Fast Intentions
  34. radiator fluid
  35. service engine soon light
  36. Potential Power Steering Issue
  37. Crank but no start 08 Coupe HELP
  38. Hypertech with IPL G37
  39. Clutch Slave Cylinder / CSC - background info
  40. Oil for upgraded AT?
  41. Help Calling all Tanabe Exhaust Owners w/ HFC's
  42. Starting issues with G37S
  43. Help After A/C compressor replaced ..
  44. Stock Exhaust Tips?
  45. Transmission or RPM issue?
  46. Strange clutch issue
  47. used supercharger questions
  48. What makes an engine "outdated"?
  49. Is my clutch going bad?
  50. g37s engine/underneath tapping noise
  51. Differential fluid quick question
  52. Sluggish off the line after battery disconnect
  53. Flip the Manual mode shift direction?
  54. SERVICE ENGINE SOON light won't go off
  55. little humming noise on highway?
  56. 2010 G37s engine clank on idle throttle
  57. Nitrous On supercharged coupe
  58. Loud radiator fan
  59. 7AT had trouble shifting or staying in 4th while in D
  60. Help!! Suggestion for G37x tuner
  61. G37 Rad Steam PROBLEM :(
  62. Reviving the G37 6MT Clutch issue
  63. 2008 G37S Engine stall on start-up
  64. Help Headers that dont throw check engine light?
  65. AWD to RWD Modification
  66. Help Distance sensor on front of G37S coupe!
  67. Help Passenger side engine mount replacement question
  68. Help Service engine soon G37S
  69. Help Engine noise and shake
  70. 2010 g37x transmission post update Itb12-027 ?
  71. Dyno numbers don't mean sh*t
  72. Adding Paddle Shifters
  73. Which will give more low end torque, TT or SC
  74. rev limiter
  75. Help 19 or 25 Row Oil cooler?
  76. Twin Stillen Supercharger...
  77. Uprev tune with a Bullydog GT Tuner?
  78. Acceleration lag???
  79. 1st Gear Transmission Issues
  80. Help knocking noise in g37 at idle
  81. Throttle Messed Up after Cleaning Throttle Body
  82. Drivetrain has a slight stutter?
  83. Z1motorsports 400 hp package
  84. E Tune vs. Dyno Tune
  85. Bouncing RPMs when in neutral but not idling - normal?
  86. T-Handle on the 6MT
  87. Q50 radiator cooling panel
  88. P2A00 Help!
  89. G37 clutch
  90. just purchased 2010 G37S (first oil change input)
  91. Any bored over G's?
  92. Has anyone heard of Mach 2 synthetic oil
  93. Weird engine noise on a 2008 G37 coupe
  94. Help Neo6 or twin turbo ?
  95. EcuTek
  96. SPORT DS mode pros/cons
  97. Help Anyone experience this knocking sound?
  98. Bouncing off redline in 7AT?
  99. Help Transmission problem -knocking noise(Video included)
  100. 7AT solutions or mods for faster, firmer shifts
