- Clutch Pedal Spring
- Help Intake manifold vacuum
- Odd engine sound
- 2013 7AT Reverse DS Howto
- Forged internals?
- Just got the r2c intake and need major help
- D vs. Ds...........
- Cluth or Flywheel problem? Glazed flywheel?
- Review Motordyne M370 & RJM pedal.
- Help RPM Surge During "Normal" Acceleration
- fair price to replace thermostat, flush coolant, new radiator cap?
- Idle Air Relearn - Quick Question
- Coolant for G37s?
- Start Up, Then Idle Drops
- Oil Sandwich plate w/ temp sensor bung
- VVEL ticking noise
- G37S coupe... RESONATOR delete..
- Help Any idea what this plug is for ?
- Help Regarding uprev and the dealership
- Limp mode?
- couple of general questions about the engine & 7AT tranny
- broken shifter suport
- New Guy + Throttle/Clutch question.
- HELP !! SLIP,CEL, light turned on after car wash
- QUICK HELP!!!! clutch spring replacement!
- Hesitation
- 2013 g37x, what octane to use
- Review 11 G37 coupe with Motordyne Products Osiris Tuned at Z1
- Help QUICK! Stock Exhaust Flange Nut Size
- Engine Horsepower Rating
- Ds --> m --> ds
- 7AT Downshift to 2nd gear?
- Need Help! Don't want to drop 800 on two new MAFS!
- Help G37 0-60 Throttle restriction?
- Automatic Diff: Gears, flanges, mismatches, Oh my!
- Help No Difference in RPM between 6th and 7th on 7at
- G37s rev. Limit
- Can Uprev change shift points & rev limiter?
- CSC and bearinf noise
- white smoke
- Clutch torque specs???
- OS Giken Twin Clutch Question
- Need Rear Left Axle Seal
- what is transaxle fluid? Is it same as Automatic Transmission fluid on a G37x.
- Original fluids
- Ses p0456
- Radiator hose/fitting sizes and lengths
- Question about Transmission Fluid
- Cranked the G37 with the TT install, Code P0102
- Clutch spring install
- Help Stillen exhaust with GTM TT stage 2?
- Got a feeling my 08 AT has a 3.357 diff
- Rb25 neo6
- Help Best CAI for 2009 G37S?
- Whats could this noise be? MT
- SES Light Limp Mode Low Oil Pressure?
- 7 spd tranny problems
- P0340 issue. Replaced cam and crank sensors. Now
- Getting a new Tranny
- Transmissions
- Gains w/ Uprev on Stock G37?
- Knocking / Clatter
- Help Gear not engaging properly ... Clutch on it's way out?
- Anyone have a GTM TT installed on a g37 sedan in the last year?
- Help Anyone get a 1 piece aluminum driveshaft for a 7AT??
- 2008 G37S, won't let the engine start.
- Is an oil cooler needed?
- 2009 7at ??
- GTM TWIN TURBO Group buy (check it out)
- Question regarding aftermarket intake
- G37x '10 to '12 Transmission
- Stock pressure plate with JWT flywheel and ACT disc?
- Need advice: replacing CSC - get new clutch too?
- Reset the ECU
- Z1 SS clutch hose
- Uprev Tune in Maryland
- Car shakes @ 1500 RPM
- Help Adding mufflers (axle-back) drone?
- Shell gasoline without ethanol
- Help Twin turbo for 350z hr for g37s
- Z Speed under engine cover
- Substitute for Pennzoil Ultra....
- Fast Intentions TT Kit - Press Release! SOON TO BE AVAILABLE TO THE G!!!
- Review Got my g37 coupe upgrev tuned.
- Slipping Clutch question!
- 2010 G37 Sedan Dyno Numbers
- Possible idle issue
- G37S Sedan on 3.916 Gears - OH MY GOD
- Help Stalled on a hill, minimal response from the gas pedal, some kind of limp mode
- General Manual Transmission Question
- okay to mix manual transmission lubes?
- Just got a pair of new turbos
- Best G37 ignition coil
- p0300 code
- Throttle lag on Manual?/ Ongoing CEL issue
- Transmission Shifting Issues
- Transmission cooler kit ?
- GTM Valve Body Upgrade Review
- 2009/2010 G37 Coupe: Is premium fuel a must
- Blitz SPC Spec-R/ twin turbo
