Help falling engine speed
Old Jun 9, 2018 | 04:57 PM
boweld's Avatar
boweld
Hello,
At the beginning, I apologize for my spelling, but I write from Poland and my English is at a communicative level.
I have a problem with my G37x 2013.
After the engine warms up, the revolutions around 900-1200 are falling to 500. This is only after adding the gas to this range. The above is ok. The suction is ok. Only how the car will reach the working temperature.
When driving in the city it is annoying.
SES is not light. There were errors P0011 and P0300, but they are no longer in error.
I changed the oil, I used a rinse aid before replacing it. I replaced the air filters. I also cleaned the MAF.
I also did adaptation of the throttle and free spins, but I know if it was successful.
I now plan to clean the throttle and re-adapt.
Has anyone had a similar problem?
thanks, Paweł
Old Jun 9, 2018 | 06:20 PM
slartibartfast's Avatar
slartibartfast
Cleaning the throttle bodies will probably fix your problem.
Old Jun 10, 2018 | 05:45 AM
boweld's Avatar
boweld
unfortunately it did not help
Old Jun 10, 2018 | 04:56 PM
slartibartfast
Did you perform the idle re-learn procedure after cleaning rhe throttle bodies?
Old Jun 10, 2018 | 05:03 PM
boweld's Avatar
boweld
Yes, I Did
It may also be that the procedure was unsuccessful. After connecting the battery, luckily, the ses error did not appear.
clx
Mar 28, 2011 04:44 PM
mystakin
Nov 5, 2010 08:07 PM
Reed19x
Mar 14, 2009 09:08 PM
dzine07
Dec 7, 2007 08:36 PM
