Help with flex disk driveshaft coupler guibo
Old 05-28-2018, 10:45 AM
rctstdroid1
rctstdroid1's Avatar
My G37 coupe 08 5AT have a vibration
and i found that flex disk, driveshaft coupler or guibo has totaly cracked.
no is my, but is very similar poor condition.
and in the FSM pag 15 http://www.nicoclub.com/manuals/G37/Coupe/2008/DLN.pdf say that, never remove " Never damage propeller
shaft rubber coupling " this part not have replacement
not is solution viable buy another driveshaft only for a damage flex disk.
not is good idea buy another driveshaft in ebay. because only g 08 5at have a flex disk. are 10 year of hard drive.
I pulled the driveshaft and measure are:
sleeve hole: 12mm
diameter from center hole 115mm
trickness of flex disk are: 30mm
here attach more information about flex disk
here catalog of other brand that use flex disk joint.
https://www.powertrainindustries.com...20Flex%20Discs
my idea is buy from another brand and put on my G
the most similar is
GAD-134 Mercedes 110mm 6 12mm 35mm
GN-132 Mercedes Benz 110mm 6 12mm 26mm
GAC02-004 Chevrolet 110mm 6 12mm 38mm Camaro V8 2010-2013
any idea please.
The following 2 users liked this post by rctstdroid1:
Bravo at (05-28-2018), Krzysztof47 (06-13-2023)
Old 05-28-2018, 11:49 AM
Bravo at
Bravo at's Avatar
Many others are in the same boat. I have similar measurements and was looking at this eBay product made by Dorman. https://www.ebay.com.au/itm/Dorman-D...4AAOSw95FZawFS.
I may pull the trigger and test fit. Thank you for the time taking to make this drawing. May need to STICKY this info some day.
Old 05-28-2018, 11:58 AM
Bravo at
Bravo at's Avatar
Here's the Dorman site for reference: https://www.dormanproducts.com/gsear...eshaft+Coupler.
Old 05-28-2018, 01:34 PM
Baadnewsburr
Baadnewsburr's Avatar
I'm in for an update on this. Its so crazy that they only sell it with the whole driveshaft.
Old 05-28-2018, 01:35 PM
slartibartfast
slartibartfast's Avatar
No crazier than the diff bushing.
Old 05-28-2018, 06:16 PM
Baadnewsburr
lol so true
Old 05-28-2018, 09:23 PM
rctstdroid1
thanks for your replay..
this a real image. i use a 2 digital caliper for all measure....
with second caliper digital i get the follow measure..
diamenter for all sleeve 22.45mm
length for all sleeve 35.89mm ... with out 2mm that enter in female 33.23mm
sleeve to sleeve diameter. center point 114.85mm or 113. 76
sleeve to sleeve intermal lenght 102.63
in your replay mercedes not fit... other idea.
Old 05-28-2018, 09:56 PM
rctstdroid1
part catalog powertrain
part make diameter hole hole lenght sleeve
sleeve
GAC02-002 Chrysler 110mm 6 12mm 35mm
GAD-134-AZ Mercedes 110mm 6 12mm 35/43mm
GAD01-010 Mercedes 110mm 6 12mm 35mm
GAD01-010-Z Mercedes 110mm 6 12mm 35/43mm
we need 115mm
but the ruber if can be strech 5 mm??
Old 05-29-2018, 06:17 PM
slartibartfast
I do not believe the rubber will stretch 1 mm, let alone 5 mm. Keep looking.
Old 05-30-2018, 08:40 AM
Bravo at
Bravo at's Avatar
Starting researching more, using different search words...Wheel spacer came up for Dodge Viper. 6x114.3 30mm, Flat.
Old 05-31-2018, 05:37 AM
rctstdroid1
umm good info.
yeah the dimension are very very same. but and ruber for vibration?
only is put 6 bushing
guibo home made..
https://www.pieldetoro.net/foro/inde....106473/page-2
Old 05-31-2018, 05:54 AM
rctstdroid1
In the BMW forum say thats a new guibo come factory retracted with metal band. for reinstall used guibo is necesary compress tool..
https://www.bmw2002faq.com/forums/to...versize-guibo/
near off 110mm
Old 05-31-2018, 02:24 PM
slartibartfast
I would consider a metal replacement if that is what it takes to get your car back on the road. I have replaced the differential bushings and transmission mount with urethane parts as well as installed the Z1 rear subframe bushing stiffeners yet find the NVH change to be quite small. I suspect replacing the guibo with metal won't affect NVH much, either.
Old 06-01-2018, 09:25 AM
rctstdroid1
whats you try to say? that i don't get nvh if i replace solid guibo aluminum? with out bushing?
i found for lexus. this
but what's will happen? with the stress in the joint in the driveshaft...
Old 06-01-2018, 09:50 PM
crookncastle
crookncastle's Avatar
aluminum is softer than steel. if anything the stress from the drive line will wear away the all aluminum coupler disc. the rubber style flex discs take the place of u-joints on a driveshaft. i would not suggest using a solid piece like the one you have in the pic. i would just try and find a flex disc with the specs closet the original one that came off the car.
Quick Reply: Help with flex disk driveshaft coupler guibo
