PDA
View Full Version : Engine, Drivetrain & Forced-Induction
Pages : 1 2 3 4 [5] 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62
  1. Help Does this look like clogged cats?
  2. WaterPump Replacement
  3. 09 VQ37VHR Lifter tick
  4. AWD Front CV/axle replacement video
  5. 09 37x sedan AWD power steering pump not lined up
  6. Help RPM plummets upon release of gas pedal
  7. Looking for cats
  8. Help 2013 g37 p0420
  9. Help 2009 G37x intermittent limp mode
  10. How difficult is it to swap the CSC, clutch, and flywheel?
  11. AT Trans Flow/Pressure Cooler lines
  12. Transmission Lurch
  13. Battery, VDC, ABS, Slip lights on. Blinking gauge cluster
  14. 7auto built trans
  15. Air/Fuel ratio, Coolant & Oil temp PLUS Oil Pressure DIY Display
  16. Bank 1 Random Lean WOT Issue
  17. P2101 throttle actuator control
  18. Car developed a ticking noise after changing gasket between cats and y pipe
  19. 5at transmission very harsh shifting and loss of power
  20. Help Questions on larger TBs, manifolds, injectors and fuel pumps
  21. Differential Leak at Driveshaft - Diff Brace Issue?
  22. Help 2008 rwd journey coupe g37 engine replacement and compatibility
  23. Looking for input: DIY Bluetooth gauges
  24. 2005 g35
  25. Help Coolant Leak
  26. Help P2096 Code but Running Rich
  27. VK56 swap
  28. First Try DIY: Oil+Fuel Pressure Display
  29. G37 problems after trans installed help is greatly appreciated
  30. Sometime have no acceleration at all but is fine after turning off/on the engine
  31. Help Ticking noise coming from driver side near the exhaust manifold
  32. Help High RPM when giving gas
  33. G37 problem
  34. Help 2008 G37 camshaft failure?
  35. Help Coolant Leaking Somewhere
  36. Oil leak near transmission mount
  37. How big is too big?
  38. Help P0171 p0174 p0731 p0305 no Start
  39. Help P1585 g sensor
  40. VHR vs HR intake manifold visual comparison
  41. Help 2008 with slow start, now it only clicks
  42. Do I need to replace fuel injector as a precautionary measure?
  43. Rattle/Screech sound at High RPM
  44. Help Rattle Noise on g37s
  45. Help Should I rebuild?
  46. Broke down 2 miles after oil change service
  47. Help Car loses power while cranking
  48. Heater Hose Connector
  49. Automatic Fluid Dain/fill
  50. VQ37VHR Universal Swap
  51. GTM motor mount rebuild part number?
  52. P0725 Woes
  53. CAN Bus control of G37 Gauges!
  54. manual g37 transmission issues
  55. PSA for silicone radiator hoses
  56. Help installing Oil Temp Gauge
  57. Help ECU replacement
  58. Help Topgunz A2A Filter / Maintenance Question
  59. Help Camshaft position sensors gone bad
  60. Help AWD on
  61. Help VDC Light - Transmission issues
  62. DIY gear swap/shimming differential
  63. Your Opinions on P0542 & P0021
  64. Blown Headgasket
  65. VVEL relay replacement
  66. Help ‘08 G37 5AT with spontaneous hard shifting
  67. P0011, P0021, P0524, p0075, p0081, p0340, p0345 check before replacing gasket
  68. Vr30 trans swap in g37x sedan
  69. Help P0300-Multiple Cylinder Misfire
  70. GTM supercharger base tune?
  71. 2010 g37xs vq37vhr to 2017 qx50 vq37vhr motor swap
  72. 2009 G37X cat rattle?
  73. Help Code P0705 transmission out - speed sensor
  74. Why I will never buy another high flow CAT
  75. Help P0420
  76. Coils keep frying, battery fuse keeps breaking
  77. Help P0345/galley gasket/ INTAKE cam play?
  78. Help Shift button stuck
  79. GTR Injectors
  80. EPS discontinued their pcv breather kit, heres a video I found as alternative
  81. Help Coolant pressure constant build-up
  82. Sudden lock up at WOT
  83. Help Gear whine on Acceleration
  84. Help Isr hfc & cel
  85. Turbo or turbo (comparison)
  86. Help 2010 g37x revving down really slow
  87. Automatic transmission replacement
  88. Car not revving past 3500 rpms
  89. Help 5at stuck in 4th
  90. Help where can i find authentic GT-R injectors at a good price?
  91. Help Header heat protection
  92. 2013 AWD Possible Driveshaft Shake
  93. Help G37 5at rpm drops then jumps back when letting go of throttle
  94. High Speed OBD Data Logging for $40+$8
  95. Help 2010 Engine into 2008 coupe?
  96. Help G37x 2009 — Grinding / Screech shortly after engine is OFF
  97. Rod knock sound P0021code - Help!
  98. G37x AT electrical shutdown at startup
  99. Help Uprev G37X 7 A/T issues
  100. G37 problems (2010 g37x sedan)
