Possible starter issue
Old Jul 12, 2018 | 08:27 PM
Fin_37S's Avatar
Fin_37S
2009 G37xS Sedan. 227,XXX miles.
So I know that my car isn’t getting a strong power draw when starting. You can hear it when I start it. Today I was leaving work, hit the brake and button and the car started but sounded like it was having A LOT of trouble doing so. Usually starts up right away with no problem but it seemed like it took some effort this time.
Any suggestions? The battery was replaced on 12/31/17. No battery light so I don’t suspect the alternator.
Old Jul 12, 2018 | 10:04 PM
stealthee's Avatar
stealthee
Starters work or they don't. Check your battery and charging system. You may have a draw while the car sits causing your hard start.
Old Jul 13, 2018 | 12:32 AM
Epiphany's Avatar
Epiphany
Definitely a low battery. Why it's low is the question.
Old Jul 13, 2018 | 05:47 AM
telcoman's Avatar
telcoman
A weak cell not accepting a full charge. Very common
Test the cells with a battery hydrometer
Then use your multimeter to measure the alternator output voltage across your battery terminals that I assume that you checked for no corrosion and tight?
You can also monitor your alternator output voltage with this from Amazon
Telcoman
Old Jul 14, 2018 | 11:36 PM
Fin_37S's Avatar
Fin_37S
Thank you guys. This has all been helpful, it’s gonna be a sec before I have the tools to check but I’m gonna test the battery for sure
Old Jul 15, 2018 | 07:13 PM
Surfnazi's Avatar
Surfnazi
Distilled water and clean off white build up on terminals
Old Jul 15, 2018 | 08:18 PM
slartibartfast's Avatar
slartibartfast
Any carbonated soft drink will clean the oxide build-up on the terminals. Rinse with water.
Old Jul 15, 2018 | 09:40 PM
soundkillr's Avatar
soundkillr
It could be the battery, or it could be the starter.
Brushes and bushings get worn, create resistance and you have drag when pulling power to the starter. I have the same issue as you do, replaced the battery and still have the same issue. My starter is old, has high resistance and has drag when starting.....
Old Jul 16, 2018 | 05:41 AM
Surfnazi's Avatar
Surfnazi
Do this not in your garage or driveway or be ready to rinse off area. The acid will leave white etching
Old Jul 16, 2018 | 03:13 PM
slartibartfast
Are you saying soda is a cheaper alternative to a pressure washer?
Zsaltzman
Jul 23, 2017 11:51 AM
Tommy Gunz PSIU
May 6, 2013 12:11 PM
fastlane45
Mar 13, 2013 01:24 PM
spyderbret
80
Aug 30, 2009 12:57 PM
PureNick
Mar 8, 2009 06:30 PM
