Knocking noise and low oil pressure after changing head gasket
Old Jul 14, 2018 | 01:33 PM
dany_rizkallah's Avatar
dany_rizkallah
My car overheated and i had a blown headgasket, i took it to a garage he changed everything in the engine and the head gasket . The engine is still knocking with low oil pressure .i did an engine pressure test all is good Any ideas why the oil is not geeting up
https://youtu.be/FdJpbYb2Rt4
Old Jul 15, 2018 | 09:45 PM
soundkillr's Avatar
soundkillr
If you have the timing cover gasket leak, you will have low oil pressure, which in turn can lead to a spun bearing causing the knock. Search timing cover gasket leak. Its internal so just because you dont see a oil leak, doesnt mean you dont have the issue....
Old Jul 16, 2018 | 03:12 PM
slartibartfast's Avatar
slartibartfast
This issue usually throws a low oil pressure code and puts the engine in limp mode.
slartibartfast
Dec 13, 2018 03:13 PM
Skatetrainer
Mar 20, 2018 10:01 PM
heyitzalex
Jul 31, 2010 11:49 PM
