- Low oil pressure light coming on at idle only
- 6 speed synchos question..have south bend clutch installed.
- Help Slip Light on 3rd gear
- R2C Filter Problem help
- Blew my engine
- Car Battery: Best Value w Great Warranty??
- 60 000 Mile Maintenance question. Differential Oil....
- Major problem on my sedan
- Help Is this a good clutch
- Mobil1 0w40 concerns
- Clutch is going I think
- Serpentine Belts ????
- Oil Drain Plug: Thread Tape? New Washer? None?
- Drive-by-wire throttle mods worth it???
- Ecu-Tek supports map switching now!!!
- 2009 Automatic Tranny issue
- CAI or Short Ram for a daily driven car?!
- Will this muffler fit?
- Rear Timing Gasket failure causes low oil pressure: no SES
- Car WONT START! help!
- Idle Sputter
- Tanabe Strut brace, will it fit??
- Rough idle at cold startup
- Engine/Transmission Issue
- During 2015, no options available to TT an X Coupe?
- What I need to know about a replacing the clutch
- GTM Turbo Removal
- G37X 2010 jerks after 3000RPM
- serpentine belt, tensioner, and idler pulleys
- Intake plenum power?
- Help 7A/T Forced Induction Issues/Problems
- Transmision Issue
- Axle click
- Problems with gas mileage after dealership visit
- *LOW* mpg help, service.
- G37 and Stroker kit
- GTM pulley (84mm or 88mm)
- Rad Hose Clamp Size
- Anyone ever get tuned from Moto-East in Easton PA?
- Anyone notice better gas mileage if manual shifting.
- spark plug replacement question
- Looking for a Rad Hose for my G37 Coupe
- Help Rattle noise at only 1100 RPMS
- Help Oil Spraying From BOV
- SES light on. confused?
- Help Oil Change from CostCo?
- ATF, need to add fluid
- Blown rear differential mount bushing
- Need help with Stillen Exhaust...gaskets??
- Transmission and diff oil change
- Good place to get tuned in North East?
- stillen bov location?
- Lookin for a sub enclosure
- Rear Wheel Clicking- Warranty Question
- Broke an axle at the track last night.
- P0300 Code along with others. Please help!!
- Help GTM 3" Turboback Baskets Downpipe?
- Our compression ratio vs boost?
- 7at ds mode
- 7AT terrible freeway downshifting
- Do I need a tune???
- G37S 2008, 67,xxx Miles, Randomly dies and
- vLSD in non-LSD
- G37xS v Hemi
- Rear differential DIY and torque specs needed
- Help repair after accident
- car wouldn't start/ battery problems
- Episodes of "Can't Start" in the cold
- Stalling issue
- Any REAL consequences to running 87/89 fuel?
- Help G37 Engine Idle; Sounds like diesel
- Help G35 Sedan 2007 Model - Overheat URGENT HELP!
- Help Po505
- AAM Twin Turbo Christmas Special
- Help Smoke coming from the grill
- Does 7AT lag issue affect model year 2013 as well?
- Yokohama Advan RG-D rims
- Brown grease 'explosion' & smoke behind front driver's wheel well? AWD problem?
- SEL maybe because of gas?
- Beck/Arnley Cabin Air Filter vs Fram Fresh Breeze Cabin Air Filter
- Cooling kits anyone?
- South Bend clutch too powerful for stock slave cylinder?
- Paddle Shifter Trim Parts Number
- Has anyone ever converted a 370z to a X is it possible?
- Totaled G w/ Stillen supercharger
- Infiniti G37s rwd awd system?
- Supercharger and test pipes
- Head Scratcher. Engine putters, loss of power, no codes
- Help Stillen SC upgrades recommendations?
- Another slave cylinder victim here, need advice
- 5th and 6th Gear Overhang.
- Engine Surge
- Bucking up hills? G37x sedan
- Performance
- Starts then turns off
- Help any ideas???
- Resonator Delete 07 G35 from Down Under
- Help Shifter Bushings?
- If only they made a more responsive paddleshifter
- Uprev Tuner in NH, ME or MA needed
