- HELP Rear Galley Seal
- How to Get the Most Power out of the G (3k Budget)
- Help!
- Got some new parts for my car in the mail today
- Changing front differential fluid, ended up snapping something. What is it?
- Help With Confirming the Coolant Lea
- Just got a 2014 7AT coupe, WTH is up with my new car?
- Ongoing Rough Idle Issue
- Stillen 19 row oil cooler
- G37 timing Chain Gally Gasket Repair Engine Codes P0021 AND P0054
- HKS EVC 6 Boost Controller- how to set up?
- Where is The Manifold Absolute Pressure
- Zspeed CSC and new master cylinder. Anything else?
- Fuel Pump Relay Location
- Help Infiniti G37 Coupe Second Gear Grinding when down shifting.
- Had to Bring the G37 to the mechanic :/
- Lean fire
- 2009 g37x acceleration sounds off
- Those with return fuel system?
- (kinda) new owner- constant clicking in the rear
- Warning lights on dash
- this time....wow..!
- HELP!! -- Reoccurring P0345 possible bad vtc sprocket
- Help Check Eng Lights wont turn off... help!
- P0021 Code - Camshaft A position timing Solenoid
- Help Transmission slipping 09 G37x
- Help Issues with my Stillen Supercharger Kit
- 08 G37 Leaking coolant
- p0300 New spark plugs replaced ONE ignition coil, error p0300 still there
- Throttle Body Coolant Hose
- Snow mode
- Motul Gear 300 LS 75W90 Shelf Life?
- Transmission service G37
- Mtec shifter spring
- Where to find a good, used manual diff?
- Help Please!
- Service Engine soon Code P0107 A (2013 G37X)
- Slight vibration before coming to a complete stop 7at 2009
- VVEL module problem
- 2010 Engine Failure/Bad
- Transfer case and valve cover gaskets starting to leak at 38k on 2013 G37x
- https://www.myg37.com/forums/general-tech-questions/287370-spark-plugs-and-coils
- Is this normal rpm behavior? (7at)
- Help G37x unidentifiable squeak under car
- Revving when braking
- G3RSTY7 Air-Air Supercharger Build
- Tuning help!
- Help Looking for help/ideas on how to Install FI RTP's
- Who has changed the LSD in their sedan?
- Help Transmission Noise when up shifting
- Lack Of Upshift Power On A 2009 G37X
- best grounding kit/ what will it do?
- Worth it to upgrade LSD while going to 4.083 gears in a sedan?
- Oil Gallery gasket service
- I've been doing research. Please let me know if I understand this right.
- BOV for Stillen Kit
- G37x 7at rpms stay for a second then lower when revving in park
- Belt squeeling noise on cold start
- Need help with my check engine light!!
- How bad is this?
- Blackstone Labs Oil Analysis
- Prepping an engine for supercharging
- Clutch master cylinder
- Help Boost gauge Pod recommendations please. ???
- P1093 code returns again days later
- Help with headers
- Intermittent ticking and jerking
- VQ owners assistance
- Wanted.. Updated ECU for Supercharged build
- Master/Slave cylinder or both??
- Car wont shift past 2nd gear
- G37 sedan Art Pipes W/ Top speed Exhaust
- Pipes
- I must supercharge
- Help with HP
- Help with HP
- Help Downshifting issues w/automatic transmission
- Changing the transmission fluid
- Oil Light Going on Periodically
- NEED HELP!! vibration when dropping RPM
- Silly oil filter question
- Limp mode '13x sedan - unlike others I've read about
- coolant coupler question
- clutch slave cylinder bleed
- Help Deciding on OBDII tool
- Help 2010 G37 P0021 code
- Deceleration
- Hesitation on acceleration in a manual
- 2010 G37S 7AT replacement
- Thinking about R35 injectors and pump info plz
- AWD to RWD conversion
- 2011 G37 overheating issue
- CMC Failure?
- Major drive belt failure only 500 miles after dealer replacement
- Help PPE Long Tube Headers with UpRev Tune?
- Help with radiator!!!!!!!!
- Help About to get Stillen SC for my 08 G37s Coupe
- Rough downshifting 09 g37x
- 2013 G37x acceleration problem “limp mode”
