- Help G37 Coupe Clutch & Flywheel
- Why the AT7 is quicker than the MT6
- Help Check engine light oil pressure code
- Help Strange 7at issues (I've serached a lot), please Help
- Bad clutch?
- Grounding kit...yes or no?
- steering wheel shaking
- Issues with shifting
- ECU Reset
- What's the best fluids for differentials and transfer case????
- Need Help from fellow nitrous users
- Front axle replacement - AWD
- AWD 09 g37 differential fluid change.
- Does this part fix spark plug tube oil leak?
- Limp Mode
- Amazon/Walmart Pennzoil Ultra Plantinum 5w30 $27.97 -$10 rebate
- PCV fittings for oil catch cans
- Oem ported lightweight crank pulley
- G37X Twin turbo Kit Questions
- Oil cooler on g37x
- Motor oil for boosted VQs
- Grinding while slowing down; worse when driving a bit hard
- Help Fuel Pump Module
- P0340 - Engine Not Starting
- Help Frozen Boost Heat Exchanger - now included with Stillen kit?
- Help Tranny upgrades
- Clutch issues
- G37x sedan cv axle help
- AWD light blinking on track day
- Extending the life of your clutch
- EPA form for HFC
- G37 torque damper
- Possible early engine failure smh
- Should I reset the computer after transmission fluid change?
- 2011 G37x Sedan transmission swap
- Help Intermittent Power Issue '13 G IPL Manual Trans
- Rev limiter in 1st gear?
- q50 tranmission module (ECU) in G37
- Adding Oil pressure guage
- auto tranny flush - any shop can do it?
- Hard start g37s Video
- Did I wait too long to change my ATF? 108K miles.
- Auto jerks forward when coming to a stop?
- Help with code P2103
- Internal engine failure, mechanic says engine replacement is necessary.
- Fuel Pump Problems (2008 G37S Coupe)
- tune with upgraded plugs?
- Help Motordyne Exhaust hangs too low..HELP!
- Engine knocking sound when car starts
- easiest way to clean Stillen long tube cai filters.
- Torque App/PLX Kiwi Fuel Trims
- Squealing noise, driveline related?
- Carbon Fiber Engine Cover
- 4.08 gear ratio
- No spark- please help
- Valve gasket cover leak
- Hypertech question
- 89 octane vs 93 octane
- Ignition coil bolt broke
- Discolored PCV hose?
- Steamy/smoke after it rains
- Help Overflow Reservoir upgrade Stillen Supercharger - Recommendations?
- 2011 g37s coupe 6mt
- g37 twin turbo gear problem help
- Output Shaft Seal Leaking
- Reducing compression
- Clutch pedal not returning after bleeding
- >>>Official Fast Intentions Twin Turbo Thread<<<
- 2009 auto 7spd transmission problem?
- I'm an idiot, help me out (6MT Clutch Issues)
- Broken Thermostat Housing?
- Very hard shift 11' X sedan
- Rattling sound coming from engine bay in drive
- Limp Mode
- ****ty clutch
- need torque gains.
- Help cranks but won't start
- 0-60 vids comparing drive modes
- Easy Rear Timing Cover Leak Test?
- Clutch help
- Paddle shifter kit question...
- Sedans: DSS One Piece Driveshaft!
- Help JK41A vs. CD009
- Clicking sound?
- New G Owner - Quick Questions
- P1734 code
- Amsoil Severe Gear 75w-90 diff fluid change
- Question about LSD
- Thoughts on this Oil Catch Can?
- Firing Order
- 5AT trans problem... car doesn't think it's in park
- Matic S Alternative
- 09 g37s coupe clutch problems *HELP*
- Where's the drone coming from?
- G37 AWD System Questions
- To replace the spark plugs or not
- engine question
- Replacing Throttle Bodies
- 6MT: 2nd Gear "hitting"/grind on shift
