PDA
View Full Version : Engine, Drivetrain & Forced-Induction
Pages : 1 2 3 4 5 6 7 8 9 10 [11] 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62
  1. 7AT question
  2. Z1 or Whiteline Rear Diff Bushings?
  3. g37 08' coupe rattle on idle
  4. 2012 G37x Engine vibration issues
  5. Help Foreign object sucked into engine head
  6. Where is the Canister Purge Valve?
  7. 2012 g37x water pump replacement
  8. Main Engine Ground Location?
  9. Axle Leak?
  10. 08 Infinitie G37 1500-2k rwhp build
  11. Help Paddle shifters
  12. What is the G37 Firing order?
  13. Twin Turbo Manual Owners Only
  14. New 2010 G37s owner, need transmission help (please)
  15. Throttle Surge
  16. What else would be required for a stroker kit?
  17. P0420 code?
  18. 08’ G37 loss of power + p300 code
  19. G37 7AT Transmission fluid change
  20. Differential
  21. Help! 2009 G37x performance issue
  22. 2013 g37x click no start
  23. Does anybody have the Color wire diagram for the g37?
  24. G37 IPL slow paddle shift response
  25. 2009 G37x sedan power issue
  26. 2009 G37x sedan
  27. Service engine light - gas cap?
  28. Don’t know if this is suppose to be connected or if it’s broken.
  29. Intriguing car starting problem
  30. FSM - Gear Oil Question
  31. Dirty Camshaft Position Sensor/Sludge in Engine
  32. Code B261F-00
  33. Rattling when accelerating from stop
  34. Slight Leak Upper Radiator Hose
  35. Did Firestone overfill my g37 with oil?
  36. 7AT - Low idle in Drive - 500 RPM normal?
  37. A/C Compressor replacement
  38. Rear Coolant Leak
  39. Windshield Washer Reservoir Rattle - video and fix
  40. Help O2 Sensor Wire - Any suggestions to fix this?
  41. Help Differential Noise
  42. Infiniti G37 - rattle at idle
  43. ECU for a MT swap
  44. Gas mileage problems
  45. Help I have a 2010 g37s with a manual transmission
  46. What’s this box?
  47. 2011 g37x rack and pinion - What's the difference between RWD and AWD?
  48. 7AT 3rd gear SHIFT FLAIR / HARD SHIFT
  49. Anyone use Dayco idler pulleys?
  50. Help Sea Foam Spray in G37 - What's the Best Method?
  51. Diameter of spark plug hole
  52. Is there a way to turn off A/C?
  53. New spark plug design?
  54. Help FI-TT with UpRev tune: cranks but no spark nor fuel
  55. Help VVL badly right sight
  56. Recommended parts change when doing Coolant flush
  57. Q40 rear diff swap?
  58. Oil galley gasket failure?
  59. Drivers side cv axle replacement
  60. Cracked flex plate
  61. Help Tips for buying used VQ37VHR engine?
  62. Car shakes only in reverse
  63. Proper Downshifting in Manual Mode
  64. Jim Wolf C2 Cam
  65. P2A00 error O2 sensor circuit range
  66. E85-Infiniti G37IPL
  67. Help $7,500 to fix timing issues?
  68. 7AT Replacement at 85k miles - 2012 G37xS Coupe
  69. Is my g37 awd system broken?
  70. I need some assistance please
  71. Please help. Weird no start issue.
  72. 2008 g37s coupe A/C not working
  73. Help Rear diff bushing leaking, what could be the problem and how can I fix it?
  74. Help Cant get my transmission to separate
  75. G37 leaking black oil onto exhaust pipes
  76. Transmission Problem?
  77. Flame map questions
  78. Overheating issue.
  79. Diff bushing in sub-frame - epoxy or rubber cement filler?
  80. 5th and reverse gear
  81. G37xs
  82. Hissing noise on downshifts help!
  83. Help Faint engine clicking at start up
  84. Z1 slave delete kit
  85. Transmission fluid change
  86. Halo DIY Help
  87. Squeal when accelerating? 2010 g37x sedan 7at
  88. Clutch and flywheel question
  89. P0011. Wimp mode at 3400. Replaced both camshaft position
  90. High RPM idle?
  91. PCV hose replacement
  92. 09 XCoupe Not Downshifting in Sport/Auto Mode
  93. Camshaft position sensor
  94. What is wrong with my car?
  95. G37 crank position sensor issues
  96. Help Changing injectors
  97. Mystery sound.
  98. Help Possible Lifter Tick?
  99. Car won't start
  100. Help P0021 P0011 VVT Solenoid
