PDA
View Full Version : Engine, Drivetrain & Forced-Induction
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 [40] 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62
  1. Help Driveshaft issue? Speed related Vibration
  2. Are these the rough downshifts you guys are talking about?
  3. Help Tanabe Full System Exhaust
  4. Sputtering IPL Coupe
  5. Ipl ecu tune
  6. Help Battery Tie Down
  7. leak in catalytics convertor
  8. Bullydog Tuner??
  9. Exhaust/Intake/Springs
  10. Was looking under the hood and saw this!
  11. Idle 1100rpm (warm) and check engine light
  12. need some help
  13. Anyone run E85 with their SC or Turbo G
  14. Help Turbo Timer Intall
  15. Idle problem
  16. Ypipe or mid pipe? Which gives more gains?
  17. Help Diameter of stock radiator hose
  18. G37 transmission flare!!!
  19. DOwnshift jerk
  20. Twin Turbo G37x question...
  21. Where is GTMotorsports?
  22. #6 Spark Plug Tube Seal Help Needed
  23. NOOB transmision Help '2012 g37xs coupe
  24. Help Oil filter
  25. 2008 G37s Engine noise when in gears at idle.
  26. 2008 G37s 5AT noise when in gears
  27. Calling 08 G37S 5AT Los Angeles/Van Nuys area.....
  28. GTM Performance Engineering: VQ37VHR Twin Supercharger System
  29. G37 Coupe Strange Exhaust sound ?
  30. GTM Performance Engineering: Stage 1 Supercharger Upgrade Kit 500whp capable
  31. SES Light
  32. Dimensions of the VQ37VHR?
  33. Please help
  34. Help GTM TT on a G37 daily driver - reliability?
  35. Softer Clutch Helper Spring = Smooth Shifting
  36. Grounding kit question
  37. Dyno AWD 7AT has anyone done this?
  38. Need help! Dtc code p
  39. 5at with Stillen SC, any problems?
  40. Help Stillen Supercharger kit install HELP!
  41. Radiator Fan ISSUE
  42. Any modified 7 speed Auto transmissions? Experiences please!
  43. 7AT Woes
  44. The G is not being herself lately... Limp Mode, Hissing Noise, Etc.
  45. Need help ?
  46. G Doesn't start.....sometimes?
  47. Help HELP! PIC Needed
  48. 2012 Tranny
  49. Stillen SC 370z on Drive
  50. Driveshaft Upgrade
  51. GTM or Stillen Supercharger
  52. Faint sound when starting up the engine.
  53. Weird noise/rattle after installing R2C intake
  54. How to increase MPG (w/ aftermarket parts)?
  55. We NEED more people with TRANSMISSION LAG to CALL Infiniti Consumer Affairs!
  56. Help Transmission compatibility
  57. Transmission disengaging at speed!!
  58. how to start a gtm s/c group buy
  59. newby here FI questions.
  60. Am I past due the oil change?
  61. 7 speed AT complaint posts
  62. Paddle Shifters
  63. paddle shifter plastic trim
  64. white car & testpipes
  65. Valve Tick??? 0.o
  66. FI & 4.08 final drive?
  67. your thoughts
  68. BG Products/Fluids what are your thoughts?
  69. G37 TT dyno
  70. What transmission is on the 2008 G37 Coupe Sport
  71. How strong are our rear ends?
  72. transmission failure?
  73. Help Clutch/Brake Fluid
  74. Crackling noise under the car
  75. Racing in a g37 6mt
  76. CAI & CBE Tune ?
  77. 2 step rev launch control
  78. Took The Plunge GTM Stage 2 Supercharger
  79. Fumoto Valve question
  80. Help Engine noise
  81. Mobil 1 Synthetic - 4500 mile change - VERY DIRTY
  82. Help Car shuts off after start
  83. Any difference in IPL engine?
  84. 2012 G37 Sedan in DS mode (Auto transmission downshift problem)
  85. recalibrating the ECU
  86. check engine light on but no problem with car
  87. 4.08 fanial drive ratio
  88. popping noise
  89. Help harsh downshift
  90. Help Temperature gauge fluctuates
  91. Anyone tried adding the 370Z rev match feature?
  92. Do you use a fuel additive?
  93. Discount for a short shifter/shift knob
  94. gummy clutch
  95. Hard time starting? 2009 G37s
  96. Help my G wont start!
  97. My G Coupe Sounds Different When Starting Up..
  98. Alltitude bites!
  99. Software questions...
  100. G37x 2009 timing belt (or chain) problem?
