PDA
View Full Version : Engine, Drivetrain & Forced-Induction
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 [18] 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62
  1. Turn automatic shift knob to mt
  2. Flush help
  3. Turbo vs. Supercharger animation
  4. Motor Mounts removal
  5. Is something wrong with my engine?(video/audio)
  6. Help Is my engine supposed to sound like this? (Video)
  7. Engine light on
  8. What bolt ons should I add to get 300Whp
  9. Do VDC, slip related to ECM?
  10. How much hp will I get from Stillen CAI,FI HFC and a Tune?
  11. Help G37 S Convertible Differential 3.916 gearing
  12. Help Power Steering pressure line
  13. IPL ECU on Non-IPL G37s
  14. Help!
  15. 2010 g37 crank pulley removal
  16. Blown Transmission?
  17. 2009 Infiniti G37 S Code P0075
  18. Transgo Shift Kit issues
  19. Harsh manual downshift and hesitation -- not the usual
  20. New Member Intro
  21. SES Code P0021 Fix - Valve Timing Control Solenoid
  22. Help Boosted Oil Temp
  23. Auto transmission shifts early...
  24. Driveshaft Flex Coupler
  25. check engine light/ stutter @ start up
  26. "VDC Off" & Slip Indicator Dash warning light on . .
  27. Can I put 11-13 engine in 09 G37S RWD
  28. What is best aftermarket chip or software for G37?
  29. Broken Motor Mounts?
  30. 08 G35 sedan manual conversion
  31. A/T cont fuse control?
  32. Engine light on
  33. Oil leaking from steering linkage?
  34. 2011' G37s Clutch Issue
  35. hp limit for daily driver?
  36. Rear axel/wheel hub clicking very loudly
  37. Already tuned: Worth a retune after exhaust change?
  38. I'm stranded on the side of the road. Please help me
  39. engine/motor mount
  40. Help Would a custom tune be worth it?
  41. Differential torque specs
  42. Puzzled with Dip Stick Reading, Any thoughts?
  43. Could be the bearing?
  44. Why would my Berk HFC cause pre-cat sensor to go off? P2A03 code
  45. A weird RPM drop, do you guys have it?
  46. Is my tranny going out?
  47. q50 transmission fit?
  48. Rear Diff removal DIY?
  49. On my second 6mt trans.....
  50. Need help please
  51. Help! P0524 code
  52. Diminishing returns...opinions please
  53. P0020 and P0300
  54. supercharger intake
  55. Coolant leak
  56. DIY 7AT Shifter Knob mod for the sedan?
  57. Help car shaking on high speed - powertrain issue?
  58. 21200-4W000 Thermostat Assembly
  59. Harsh downshifts
  60. Acceleration Problem!!
  61. Help Valvebody and torque converter upgrade
  62. Anyone know of a 7AT upgrade?
  63. Catalytic Converter Rattle & 80k Emissions Warranty
  64. 6 puck metal clutch disc??
  65. single turbo kit
  66. Automatic Transmission Problem?
  67. Help Vibration 4 a few miles, then gone + very brief power fade
  68. Diff bushing
  69. Whats the ball park range to repair g37 engine/tranny?
  70. What are you using for transfer case and differential oil?
  71. P0524 and low oil pressure
  72. Car is revving when ac is on high or is really hot outside.
  73. P0524 and low oil pressure
  74. '11 G37s clutch problems
  75. Service Engine Soon..........
  76. Nismo 370z Stillen supercharger compatibility
  77. G37x 7AT Transmission Problem
  78. Oil change question
  79. My G37 IPL Engline light popped up and I'm currently at 25k miles.
  80. Help Stillen SC head unit belt replace
  81. Transmission slip? and jerk (first time)
  82. Accelerating Rattle
  83. Safe to use this gear oil?
  84. ABS, Slip, AWD, VDC, Brake, TPMS and Key Light all ON
  85. Is there any hope for the 7AT?
  86. NST Pulley
  87. whats the difference in horse power of the G37,G37S and G37XS
  88. Burning smell at 5000 rpm
  89. G37x CV Shaft removal drivers side
  90. G37x front CV shaft recommendations
  91. Question about Transmission fluid replacement and others!
  92. Rad cover removal air flow question
  93. Upper radiator hose leak?
  94. Transfer Case Confirmation
  95. Ford turbo on g37x ?
  96. Stillen Generation 3 CAI Quality/craftsmanship
  97. Engine/Transmission noise?
  98. G37 coupe won't stay in sport mode. Goes back to Normal drive
  99. Help worn U Bolts and left cat loose internally?
  100. 7at delay going into reverse
