Pulled the #6 plug
Old May 19, 2018 | 04:49 PM
Flakman's Avatar
Flakman
Pulled the #6 plug
Changing the plugs and find this lovely sight
Oil in #6 plug cavity. Not excessive, but not good.
I imagine that's a head gasket and plug o-rings at a minimum. Anyone deal with cost on this? Not sure if it's worth tackling myself.
Thanks
Old May 19, 2018 | 08:56 PM
slartibartfast's Avatar
slartibartfast
Why assume head gasket? If the o-ring is leaking, just pulling the plug through the pooled oil will cover it like that. Do you have a photo of the electrode?
Old May 21, 2018 | 05:45 AM
Surfnazi's Avatar
Surfnazi
Isn't that a bit personal...at least but him dinner first.
Looks like seal is bad
Old May 21, 2018 | 10:41 AM
Flakman's Avatar
Flakman
Electrode looked okay. Bunch of carbon buildup on that whole bank. Oil was only in the plug hole, not in the cylinder. Maybe I'm thinking valve cover gasket. Would that not need to be replaced if getting to the O-ring for the plug?
Old May 21, 2018 | 10:44 AM
Flakman's Avatar
Flakman
Also a movie depending on the plug.
The amount of oil was minimal, brief spot of white smoke on initial start after doing the plugs. She runs great measuring by butt-dyno. Hopefully the pre-det will be much less as well when under load.
Old May 21, 2018 | 10:49 AM
slartibartfast
Isn't that a bit personal...at least buy him dinner first.
No comprendo.
Old May 21, 2018 | 04:43 PM
Baadnewsburr's Avatar
Baadnewsburr
You can replace just the seals on the G37 and not have to change the whole valve cover (unlike my second gen G35 sedan the earlier 1st gen g35), but you probably should change the valve cover (not head ) gaskets when you do.
Old May 21, 2018 | 07:12 PM
Surfnazi's Avatar
Surfnazi
Next time seafoam the car via brake booster and add what's left into oil 100 miles prior to oil change
Old May 22, 2018 | 09:44 AM
Michael_in_DE's Avatar
Michael_in_DE
I'm also voting valve cover as well. Seen the same thing on my old Audi, and similar things on my Ford truck.
Old May 22, 2018 | 02:00 PM
Surfnazi's Avatar
Surfnazi
Just replace the oring
Old May 26, 2018 | 03:16 PM
Flakman's Avatar
Flakman
I'll take a look at the O-ring replacement in the FSM. Thanks guys.
Old May 27, 2018 | 09:16 PM
qmantran's Avatar
qmantran
spark plug tube seals.
koelzmod
Oct 3, 2008 01:01 AM
ATOPA
The M - Spot
17
Apr 11, 2007 09:37 PM
