- 2009 G37 Engine Problems
- Front axle issues again
- vlsd swap g37x
- Transmission Fluid in Engine Oil
- Help Constant ticking noise
- Help After start, engine shakes violently then dies
- Help 2013 g37x sedan sluggish all of a sudden
- Transmission reprogram after speed sensor replacement issue
- Timing chain popped with codes P0524, P1217
- Adjusting Cam Phaser Ring (Fix for P0011/P0021)
- New Clutch not Engaging... Money Pit
- Car stuck in DRIVE PLEASE HELP
- New CMC/CSC, Clutch Etc
- Yikes. Lean after tune
- Crank position sensor issue/p0335 code
- Coolant leak towards rear of engine
- RPM Bounce and Dips
- Intermittent P0302 misfire identified
- Help Clutch Pedal on the floor
- P0021 and p0524 codes
- Help Oil temp sensor issue
- Help Intermittent Start
- Help 2007-2008 VQ35HR compatible with 7 speed trans
- Help Boost gauge peaks at -17 vacuum
- Fuel Gauge Stuck Empty
- Review Gallery Gaskets: EPS vs Z1
- Help Transmission acting weird. Am I screwed?
- engine limit
- 05-12 Pathfinder differential cover swap
- Need new engine :(
- Help 280k Mile motor consuming oil. Replace valve seals?
- Help Help Sourcing Possible Oil Leak
- Help Gally gasket
- P0720 and valve body/TCM compatibility
- Help Acceleration Not Quite the Same
- Code P0744 Torque Converter
- Help Clutch Pedal sticks to ground ONLY when car is on
- VR30 transmission in AWD Sedan problem
- DIY Clutch Swap - How hard?
- Used vr30 transmission rebuild
- Engine Bay Missing Part Help
- Flex Plate replacement Z1 or OEM
- Help G37x ECU Replacement Compatibility
- Help Replaced all 6 ignition coils but CEL's P0302 and P0106 came back on
- Help 2012 g37x coupe valve body replacement (P0720 code)
- Help New engine has stock oil cooler, old engine does not
- Updated Gallery Gasket
- Help no start after oil gallery gasket job
- 2011 G37xS - Need 2nd opinion with code P0300 - random/multiple cylinder misfire
- 2010 G37x sedan - idles like it's breathing?
- Help Vibrant exhaust defouler, which plug?
- Water Pump?
- Help Huge Timing Chain/Cam Sprocket Job
- Help I need to know what all year G37 motors are compatible with 2010
- Cold weather battery drain (VCV already replaced)
- Strange chirping VQ37VHR
- Help Clutch Replacement
- Engine rebuild for forced induction
- Help Coolant reservoir filled with black oil…
- Help Replaced Cam Position Sensors Now Crank No Start
- Got Rear Ended (again)
- Which model of engine oil cooler is right for my use
- 2010 G37: Starting Problem
- Help Oil pressure + temp sensors
- G37 coupe engine swapped won't rev past 2.5k rpm
- Help Car repeatedly won’t start in cold weather
- Help shift knob stuck/won’t go into park
- Help P0335 Crank Shaft position sensor
- Help 7AT cooler flow direction
- Whats the best way to approach replacing engine control harness on 10' X coupe
- Help Error Code P0302 and P0106 (CEL) - Is it just Ignition Coils?
- Clutch and flywheel replacement job write up wanted
- Permanently remove front axles?
- Help I Cleaned out my throttle bodies and now my car runs horribly
- Will 350z twin turbo kit fit G37x with some work?
- Fuel gauge
- Help Is my CAN-bus voltage issue being caused by my TCM or by bad harness grounds?
- Help Loud tick coming from motor after driving
- Help Engine possible done from water
- 7AT needs new valve body but runs fine
- Help Code P0011 Fix
- P0021, p0300, p0524 AFTER gallery gasket R&R
- 3.692 Carrier (2007-2008) Swap into 2011 Auto
- 2009G 37X all-wheel-drive four-door sedan
- 7AT RE7R01A Transmission Rebuild
- Found this article Interesting - Explains possible Oil Consumption
- Vibrations everywhere!
- 7AT Cooler Kits
- Winding noise when letting off the gas
- G37 6MT with engine performance problem
- Help A2A V1 Filter Upgrade Questions
- Gallery gaskets or something else?
- Help Im going insane! HELP!
- Help P0021, P0524, and P0300 AFTER rear timing cover gasket replacement
- Help G37x Transmission Issues - Dealer Update Created
- Low Low mile g37x just purchased - Maintenance Question
- Help Transmission output sensor failure
- Help Engine bogging
- Help Mystery jerking and lag
- Engine replacement cost
