- Only a click when trying to start
- Throttle lag, no acceleration
- Clutch Master Cylinder opinion please
- Transmission service maintenance schedule?
- Contemplating 3.9 gear swap
- LS Swap, TT Kit, Or SC Kit?
- Anyone use an insulated clutch cable?
- G37 AWD and trac control
- stillen super charger
- Newbie owner - D to DS mode often bad for car?
- Drivetrain fluids, when do they need to be done?
- My Transmission is acting up!!!
- Replacing my transmission at 115k miles....
- Bummer...2nd OEM CSC failed on me.
- Car wont start, no key indicator on
- P2M Energy Halo Velocity Stack for Throttle Bodies
- Zspeed heavy duty CSC broke on me??
- Transmission Change
- 08 G37s 6MT transmission noise
- Help Locked torque converter?
- 2012 g37X Idle stumble Seafoam?
- Help Who has Uprev Osiris Rom editor or tuner
- Part #s and DIY link for timing gasket failure
- Can't find a variety of pulley sets
- Help Southbend Stg2 Clutch/flywheel / zspeed HD CSC
- Maintenance Engine Oil in instrument cluster
- Odd metal on metal noise and clicking
- Code p0725 popping up.... help
- Differential Service- Flush Rear And Front?
- Where to buy these hoseclamps
- Help Weird high pitch noise on G37x 2012 Auto on highway speeds 70-80+ mph
- Anybody running GTM SC kit w/ Uprev?
- NEED HELP!! My G37 won't crank after new cam/crankshaft sensors
- Transmission slip or something else? Help!
- What fuel do you use?
- Paddle Shifters Install
- Too late for a supercharger?
- Help Straight Pipe + Axle Back?
- NGK plugs 4554 yes or no
- SC kit vs TC kit opinions
- Need help - car shakes violently G37X Coupe
- Radiator Cooling Fan
- 2008 G37S throwing p0300 code and need help!
- Idiot filled my car with 87 octane
- Won't shift completely into park
- Service Engine Light CODE PO300 PO301
- 08 5at
- Car shakes and I've done just about everything..
- I need help with power loss
- Clunking noise from the rear 2010 G37S coupe
- G37 turbo kit manufacturers today?
- G37 6mt clutch replacement advice
- GTR Paddle Shifters
- Lash/Play in drivetrain
- Neeed Helppp Clutch & Flywheel Replaced i get no gears???!!!
- 7AT Stillen Supercharger
- Issue with car starting.
- P0011 -_-
- Shift knobs?
- Help squeaking noise coming from trans
- 2013 G37 Sedan 2nd Timing Seal Leak
- Help 08 g37MT Clutch issue
- Tranny sliping
- Engine codes
- Help G37S in the shop for manual tranny work
- Reading transmission fluid temperature
- Car had the shakes!
- How much $$$ to get my G to 400 WHP?
- Help 09 G37s coupe
- Torque App, Transmission Data
- G37 Rough Idle Need help!
- Help Gears stuck? Please help
- FI HFC or RHFC
- Tranny and Brake Fluid Flush...ripped off?
- Stock engine material
- Differential Fluid Question
- Lets talk rear mounted turbos
- Final drive gear ratio
- Intake Plenum air routing
- Aggressive Driving to get Power in the G37s
- Transfer case rear seal
- BERK HFC safe site???
- Help G37 IPL Clutch falls flat to the floor
- G37X 3rd-4th/4th-5th Upshift Jump In RPM's
- Is there a DIY for the shifter assembly?
- 2009 6sp manual issue
- 5 Speed Automatic Transmission Fluid Change Question
- Gearbox G37S Coupe
- Car wont up-shift/rev over 3500rpm/jerking (with video)
- Awd module
- 7AT ATF flush
- Minimum Engine Speed
- trying to troubleshoot vibrations while on jackstands?
- G37x & Stillen long term?
- 2011 G37 coupe won't start this morning. Help!
- 2011 G37X manual shifter mode
- Help g37x coupe front axle
- Aftermarket Intake Air Temp Sensor?
- Transmission revs up between 3rd and 4th
