- What oil filter do you use?
- G37s single turbo build - Goal: 800+ HP!!!
- How to totaly disable traction control?
- ECU update
- G37 doesnt start, lights wont go off, tail lights flicker
- Seized Engine Replaced/Now Vibration
- Help Engine makes a knocking noise
- 7AT / 7 Speed Transmission Service
- Vented fender liners - Has anyone done it? (Especially you FI'ed guys)
- Adding paddles
- Before and after FI track numbers?
- need intakes help
- Help car feels slow when the tank is full?
- Differentials 101
- Just jumped on the FI ship
- Another bad master cylinder & slave cylinder
- First oil change early?
- Engine Air filter
- Shift Knob Options for freezing hands!
- Possible to get a 5AT to launch from 2nd gear?
- Finally: The Real Solution for Crappy Clutch Pedal
- g37 revs limited?
- APS twins
- oil change minder redundant
- cobb tuning chip question
- $385 for BNIB G37 Berk HFC!
- GTM VQ37VHR Stage 2 Supercharger on Meth: 507whp/357wtq
- Problem with DS mode when stopping
- g37 340+ whp
- '09 XS, hitting rev limiter at WOT 1st-2nd intermittently
- Did Infiniti fix the transmission lag for 2012 model
- Who has a Stillen G37 Supercharger? Numbers, pics, vids!
- Coolant Cap
- Gas pedal - no response
- Can't find Block Heater plug
- Where to get a one piece driveshaft
- Can I disable the clutch start button on my 2011 6MT
- 5spd vs 7spd
- Throw Out Bearing Problem?
- winter oil weight
- best fuel additives?????
- Oil change
- Help Erratic RPM?
- My Nitrous Set Up
- Motor mounts on a g37
- MOTORIA exhaust system
- Nitrous NX Kit
- 0W30 Motor Oil
- Finally pulled the trigger on R2C Intake!
- Physically possible to hit transmission first?
- Convert automatic to manual?
- AEM ON-VEHICLE Dyno!!
- HELPPP please!!! loss in power
- TWM Performance Short Shifter Review
- Matte Black Stillen Gen3 Intakes
- Winter gas?
- Dipped into redline
- Oil
- Am I the only automatic owner with no complaints?
- 2011 G37x Sport Flare Issues
- Nitrous?
- How do you know when AWD is engaged?
- Horsepower
- Did i mess up my transmission?
- over revving??
- Help Trouble with my g37
- EGR valve
- New volks
- High idle and rev hang after cleaning TB
- Gear and Rpm Problem!
- Acceleration into a parking spot on the brake
- GTM Stage 2 SC Completed
- Forged Performance: 636whp G37 Coupe!!!
- Shift difference between D and DS.
- Losing power on 1st and 2nd shifts?
- Nailed a curb - Wheel Hub Replacement Needed (G37x)
- Hfc
- AWD coupe system
- Automatic transmission downshifting abruptly
- shifting into 6th gear?
- Diff bushing
- 6mt low end torque
- turbo question
- Details on 0-60 mph throttle restriction?
- my car drives like crap in cold weather
- after changing water pump and gasket due overheat help plz
- Transmission fluid change needed?
- 4.083 FD...oil cooler?
- Post 1/4 mile time - Dynos not welcome
- Help Service Engine Soon - HFC/TP o2 Sensors (P0420 & P0430)
- Clutch Delay Valve??
- LSD and AWD
- Leaking differential
- Uprev tune and Warranty/ Maintenance
- Question about engine
- Weird noise??
- HELP! G37x Problem
- Help Hesitation/Bog/Sputter @ 3k RPM
- VVEL and Throttle Bodies
- Help TWM Shifter Group Buy
