PDA
View Full Version : Engine, Drivetrain & Forced-Induction
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 [48] 49 50 51 52 53 54 55 56 57 58 59 60 61 62
  1. Transmission problem 08' g37
  2. new engine....odometer?
  3. Slid in DS mode
  4. DS mode, mash the throttle
  5. ping / ticking noise?!
  6. Opinions
  7. 7at downshift rev match benefits
  8. About Gas : 87 or 91 or 93
  9. Re: Vdc off/slip
  10. Problems with 5AT shifter not working
  11. Button on Automatic Stick Shifter locks
  12. 7at ds..
  13. My G is in the shop! They broke my cat!
  14. Should I Install the UR Stock Size Light Weight CRANK Pulley?
  15. Review Grounding Kit that I've Made
  16. Help I just want to squeal some wheels, man.
  17. HEADERS over intake and all...
  18. Aftermarket Clutch/Flywheels
  19. Clutch Options
  20. CAI (cold air intake) Reviews....
  21. New problem!
  22. Supercharged experience
  23. Stumped...bearing noise from Trans when in neutral
  24. What's going on?! Car won't start again.
  25. 2010 G37- Cold Engine Start up Noise
  26. ECM Problem with 2009 G37 Sedan
  27. Should i stay in low gear as long as possible?
  28. Help Quick question about UpRev tune.
  29. Will adding Paddle shifters to non-sport G37 void warranty?
  30. Is the Stillen Gen 3 intake compatible with a GTM TT?
  31. No More Throttle Lag
  32. Help Gas pedal
  33. got oem M1 filters for a good price
  34. G37 7AT Issues - Poll and Consensus?
  35. 2010 w/6300 miles and a "Service Engine Soon" light
  36. Car died yesterday
  37. Can TT or SC be disable and enable at will?
  38. Clutch slipping help?!?
  39. Clutch fluid change -
  40. Can you eliminate throttle lag completely??
  41. "Heavy" clutch replacement?
  42. 2010 G37xS sedan dyno
  43. Good Tune shops in or around North carolina?
  44. Help 7AT Dyno
  45. Convert AWD to RWD
  46. Improving 5AT Performance
  47. Amsoil synthetic transmission fluid? Anyone done it
  48. Adding one quart of Redline Ester based oil
  49. Clicking
  50. Manully shifting the 5AT
  51. Transmission down shifting issue - Fuzzy logic
  52. Redline
  53. Oil Cooler?
  54. GTM Performance Engineering : GTM Stage 2 TT Turn key Kit, 525RWHP/466RWTQ
  55. car starts stuttering at 3500 rpm, wtf?
  56. Help First oil change?
  57. low octane fuel
  58. Less Drivetrain Loss? 5AT
  59. Help My car keeps shutting off! Wtf
  60. Help Maintennance on a SC kit.
  61. Problem with Transmission 5AT
  62. 300V 5W30 Virgin Oil Analysis
  63. Clutch pedal reduced travel on cold starts
  64. 1 to 2 shift too late with 7at manual mode
  65. power steering fluid
  66. Custom dyno tuning to improve gas mileage? Possibly make more power as well?
  67. What is your RPM at 80 & 60 mph in your G37 sedan? Auto? Manual? G37x?
  68. Help Any ideas????
  69. How to Manual Shift in a 7AT
  70. 400HP Possible N/A?
  71. Invidia Q300 Cat-Back Review and Installation Guide
  72. Gas mixing with Oil
  73. FS : G37 paddle shift kit + cover
  74. Help Think I'm toast -- help please
  75. G37-Journey-auto trans
  76. Engine Shield - Underneath Engine
  77. blown rear end
  78. 6MT owners: RPM @ 60MPH, in 6th?
  79. How does your engine rpm response when you floor in 4th @ 80 mph?
  80. change oil after first 1000 miles?
  81. Does the R35 GTR Turbo Manifold fit on a VQ37?
  82. New G37 TT
  83. Help engine not starting!!!
  84. Help Chattering/Rattling Noise sitting in Neutral
  85. VQ Motor getting long in the tooth?
  86. Help Need help w/ my G37S! New exhaust, headers, intake and tune up!
  87. Help Rocks in the Heatshield??
  88. Oil cooler
  89. Exoticspeed RII-Titan Exhaust + High Flow Cats
  90. Sena's Grounding Kit
  91. Throttle Body cleaning / Induction Carbon cleaning
  92. Driveshaft/Trans/Differential Issue??
  93. 6MT and throttle lag?
  94. Ticking feeling/sound on cold start
  95. Lunging / Jerking
  96. question before going FI
  97. Thud when pushing in clutch pedal?
  98. Engine seized on new x coupe- any ideas why?
  99. Sprint booster, anyone seen/used this??
  100. 7AT Shifting Issues
