- Most mileage
- Clutch Issue
- Oil cooler on track with low ambient
- final drive on 5 AT with VLSD
- slave cylinder
- Help Undercarriage engine cover
- Computer updated ?
- Stillen supergarger
- Help GTM SC for G37x is NEEDED
- Failed CSC (pedal stuck). Is it covered under the powertrain warranty?
- New tranny, new problems..
- Help Clutch Pedal on the floor
- Trans flush
- Oil temp gauge
- Shifting problems
- Heel & Toe Technique
- Hot and Cold Clutch pedal feel
- Transmission Issues on 2009 G37X Sedan-To Buy or Not to Buy
- The time has come...
- Question about Engine mounts
- Changed my LSD and MT oil this weekend
- lightweight driveshaft or lightweight flywheel
- FI and lightweight flywheel
- Help Error Code P0643 (Sensor Reference Voltage "A" Circuit High)?
- g37 coupe wont ignite
- Anyone change/mod/figure out their 6MT clutch?
- just got my 08 Infiniti G37 5-spd auto transmission replaced
- Rough morning startup
- Replace flywheel with clutch?
- oil consumption concern / considering a 2008 - 10 G37 S Coupe
- Push-button Starting Problem
- Help Broke Clutch Bleeder valuve, suggestions?
- Resetting the ECU in a G37 (with new mods)
- G37X Sedan Twin Turbo
- Help G37 Pings while idling/driving
- help with exhaust..
- Why is the 6MT transmission so big?
- 09 G37 7AT Tranmission Question...
- Stillen SC Build = 500 WHP?
- Vavoline Non synthetic
- Cobb AP Questions!! HELP!
- clutch questions
- 35,xxx WITH NO OIL CHANGE. WHAT DO NOW?
- Exhaust for GTM TT kit
- Help thin air
- G37 IPL Transmission Failure (twice in <20,000 km)
- 6Speed custom shifter
- 6MT owners, change out your clutch fluid regulary.
- fuel efficient overdrive gear/transmission
- Clutch help!
- Windows rolls down but not go up Except power sent to the motor
- Cobb, Uprev (Osiris) or Hypertech help for 370GT Skyline
- Wastegate rerouted vs dumped
- Driving then going into reverse?
- Help AT Service Bullietins
- Driving DS mode ?
- 2012 G37S 7 speed transmission
- G37s 6 speed single turbo build big power
- 7AT? coming from a 370 to G37
- Uprev tune SD?
- What 3" exhaust r out there?
- Help 850CC injectors?
- Car runs worse AFTER bolt-ons
- Strange engine whine noise
- Review Drop Engineering Transmission Mount... reviewed
- Finally installed my Z1 aluminum driveshaft!
- Weird clutch noise at idle
- ACT Clutch Kit
- Starting steps
- Ticking sound normal (Video)
- Intake options?
- Downshift with AT
- Trans fluid
- Clutch brake fluid vanished
- Help Broke Down
- Questions about possibly purchasing an ARK Exhaust.
- Disabling VDC
- Review Transgo Kit for 5AT
- Shifting Question
- Review Stillen Short-Throw Shifter w/ NISMO Ti Knob
- DS & Manual Mode Lost / Hijacked
- Temperamental Acceleration/RPM
- Injen SRI replacement filter?
- newbie asking about fuel type
- Check engine light
- ECM Relay Location
- G37x Exhaust Layout
- Single turbo build 550 whp, bolt on kit for under 6000$. No joke
- Review GTM Stage 2 Supercharger
- Help Any DIY for draining/refilling engine coolant?
- GTM Performance Engineering: GTM TD05 16G Test Results 91 Octane 7AT
- Details for big service ?
- tuning my car.
- For all the 09 owners that didn't know...
- Oil cooler for daily driver?
- Vibration when in gear and stopped
- GTM stage 2 SC installed & question about stroker kit
- Help Which way to go? VB upgrade or TQ upgrade
- UPREV Tune, maybe issue?
- Help Clutch problem?? :-(
