- Help What is the Magnaflow catback like? Help!
- Help 08' G37S Tranny and Diff fluid change question, help asap!
- Clutch/Flywheel Combo for good price.
- 7AT Noise on Incline
- VQ tough on oil
- Post 7AT Reflash problem
- RPM dips low at idle
- Updating the ECU...
- JWT POP Charger
- No gear number shown when initial shift to DS
- Help Test Pipe / HFC Install!
- Auto Tiptronic Owners - Has this happened to you?
- check engine light covered under warranty?
- Lag
- Low fuel acceleration lag? DS shifting issue
- Which cold air intake for '11 Vert?
- Specified fluid for the front differential on AWD?
- Full synthetic to Partial Synthetic - is ok?
- Performance after transmission software update
- Help Snake Oil?
- tune and dyno from church automotive
- Weird Clutch feedback!!!
- Fuel Mix Up
- New G37x coupe...coolant leak
- Injen Long tube CAI on 2011 G37 Sport
- Brand new G37s Coupe differential fluid leak
- '10 G37S power loss, overkill VDC/slip, and suspension/steering lacking...
- yes yes i made another catch can thread
- 03 G35 engine dies...?
- Supercharged VQ37 goes BOOM!
- Have $1,000 - What should I buy?
- Compucar Nitrous in a bag Universal FI dry kit
- Transmission Replaced
- Acceleration Shudder help!!
- Gonna make a catch can
- LSD on a G37x
- Proper AF range for turbo \ stock application
- Help CEL after a year with GTM RTP
- Carrier installation?
- Oil change every 3k? 5k?
- g37 burning oil
- Battery relocation to trunk?
- 5 speed Auto transmission thumping noise.
- G37 Coupe Popping/Crackling Noise
- paddle shifter
- K&N Air Filter +HP??
- Difference between "D" and "DS" with paddleshifters?
- MXP Horsepower Gain???
- mpg suffering
- Do I need a tune? Gen 3
- K&N Electric SC
- Question about 5AT shifting in normal mode
- Engine Covers - now closed thread
- Good Article on Gas
- Genuine Engine COolant?
- Steam from grill area during rain
- ATTESA VS Quattro (ATTESA haters learn your powertrains)
- G37 Coupe 2 more HP than Sedan... Why?
- Aftermarket alternator pulley?
- Gen3 suggestions
- Vlsd
- Cnt cbe
- Another GTM Convert: GTM Supercharged G37
- Any have experience with m2 performance?
- Finally Fixed Shift Lever Problem
- Custom Overflow tank... Interest.
- Dealer Updated my ECM for 6MT fix???
- Computer/Transmission problem. need help!
- Synthetic oil
- Aftermarket Fuel Filter Suggestions ??
- 'en cold or Will an SC work in this temp? Burrrrrrrr
- Tune without aftermarket CAI/SRI - Thoughts
- Engine cover foam pad
- Operating oil pressure
- GTMHKS GT supercharger?
- firecracker noise under the car?
- 3/4 throttle on on ramp was a joke in drive mode
- GTM supercharger for G37X?
- 2010 g37x transmission same as fx50?
- Strange RPM stutter when accelerating
- high idle and check engine light
- RPM's issue (video inside)
- Octane 87 vs 91
- Stillen Intake ?
- Had my manual fluid changed, and small chucks of metal came out??
- Probably trans/drivetrain problem caused by big pothole hit..
- Dyno Time
- Help $1400 to spend
- Is the clutch replaced with transmission?
- e85 on a stock tune
- Help Berk vs Fast Intentions.
- That TURBO Blow off is OHH SO GOOD - I want it!!
- 2012 g
- Probably first STILLEN VQ37 SC install in Russia
- Over heating with F.I
- Question about throttle @ higher RPMs
- Have an auto with paddles? The best $2 mod ever!
- GTM and Stillen SC Install Facts and Results Thread
- Gear box locked up?
- G37 2010 coupe//7AT trans question
