Oil pan drain plug stripped?
Old Jul 29, 2018 | 06:34 AM
Rich11G37xS's Avatar
Rich11G37xS
So I went to change my oil the other day, got the car on ramps, get to the oil drain plug , get it turned a 1/4 turn. So I'm waiting for the oil to come spewing out...nothing, so I turn again, still nothing. At this point in just keeps turning. Is it stripped ? Hopefully I can get it off with an impact wrench , which I do not own. I have left it be for now, at least till I my new drain plug gets here, in case it is stripped, which it most likely is ? any suggestions ?....hopefully my oil pan threads are ok
Old Jul 29, 2018 | 07:49 AM
KidJai06's Avatar
KidJai06
Are you saying the plug keeps turning without coming out at all? The oil will (should) only come spewing out once the plug is completely out of the oil pan. Was the plug tight when you started? When you gave up were you able to retighten it? The last time you changed your oil did the plug go in smoothly?
Old Jul 29, 2018 | 09:14 AM
If you can get a screwdriver or a small pry bar under the bolt head while you turn it w/ a wrench (so you can apply outward pressure) you may be able to engage the next row of threads and get it out. If not you'll have to remove the pan and go from there, hopefully pan threads are fine.
Old Jul 29, 2018 | 08:31 PM
Baby Jumpman's Avatar
Baby Jumpman
I’d just order a new oil pan from rockauto, they are pretty cheap.
Old Jul 30, 2018 | 03:08 AM
JSolo's Avatar
JSolo
Just say no!!!!!
An impact on an oil drain plug?!@#
If it's stripped, should turn with little effort. I'd say don't attempt to tighten to drive it someplace. Your oil change may turn into an engine rebuild/replacement.
Do you typically do oil changes yourself or take it to the shop? How recent was the last change?
Old Jul 30, 2018 | 08:46 AM
Baadnewsburr's Avatar
Baadnewsburr
this is a good suggestion, it should come with a new plug too
got any pics?
Old Jul 30, 2018 | 09:53 AM
Rich11G37xS
Impact to get it off, is all I meant...yes I have always changed my oil and have never had this problem...last oil change was last fall....4k miles ago
Old Jul 30, 2018 | 09:56 AM
Rich11G37xS
the bolt didn't seem overly tight, yes I was able to re tighten it and last time I changed the oil everything went fine
Old Jul 30, 2018 | 10:55 AM
Michael_in_DE's Avatar
Michael_in_DE
If you turn it continually and it does not come out, yes, of course it's stripped. How that happened? No idea, but frankly you did something wrong. It happens. Get a new pan, plug and gaskets. Looks like less than $65 total on Rockauto. Even less on Amazon. I would not drive your car until you get it fixed.
Purist
Jul 21, 2025 01:07 PM
Mattlorentzoe
Dec 26, 2020 06:03 PM
toka3620
General Tech Questions
Nov 8, 2016 05:44 PM
Overboard
Oct 13, 2016 10:09 PM
