PDA
View Full Version : Engine, Drivetrain & Forced-Induction
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 [22] 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62
  1. 09-14 coupe 7at driveshaft measurements
  2. Help! 1 piece aluminum driveshaft doesn't bolt up
  3. Rear-mounted turbo for the X?
  4. Blank Dashboard
  5. Transmission slipping?
  6. Manual Transmission Fluid - Question
  7. Why doesn't Vortech have a supercharger kit for vq37?
  8. Manual mode in an Automatic
  9. Block hailrine crack in water pump housing
  10. G37 and 370z rear axles
  11. Airplane gas???
  12. 2011 G37 Sedan Overheating Idle
  13. Replacing transmission at 110k
  14. Swapping engine
  15. 110k miles should I turbo??
  16. To All VQ engines, Pls. check your cam cover for oil weep, dampness, leaks
  17. Drivetrain vibration
  18. Is supercharging a 7AT worth boosting?
  19. Diff bushing blown
  20. 2009 G37 motor Knocking and motor shaking
  21. PSA To those whom may have a FIDANZA Aluminum Flywheel
  22. Improving response of my 2008 G37S w/ 5AT
  23. Gears are grinding. Don't know if it's syncros
  24. New to the Forum got a clutch question
  25. DTC P0455 - Evap Control
  26. Engine Cover hydro dipped
  27. Help Test pipes with Stillen SC
  28. q50s to g37 coupe motor swap...
  29. RJM Pedal Adjustment
  30. 1st and reverse gear grind when letting clutch out?
  31. Help Test Pipes that fit AWD Sedan
  32. Clunking/thump when shifting
  33. Whiteline bushings installed wrong?
  34. Help Rattling noise from underneath
  35. HELP 2009 G37S 3rd gear grind
  36. 6mt stuck in 5th gear
  37. Rough idle
  38. Turbo G37 with mildly high miles?
  39. Z1 oil cooler install issues AWD
  40. Help Aluminum Driveshaft for G37 AWD?
  41. Help Rattle from engine
  42. Weight reduction of rotating masses
  43. What to do first?
  44. Hesitation Upon Accelerating
  45. 1pc aluminum/carbon fiber driveshaft w/ 4.08 gears
  46. Any OBD-II Wifi PC Software?
  47. Motor Mounts?
  48. Thinking on adding a nos system to my G
  49. Hesitation and CEL
  50. high idle
  51. VDC & SLIP ON Codes U1000 & U1001
  52. Disabling VDC
  53. vibration around 3500 rpm
  54. Help installing paddle shifters on g37x
  55. "help" Need to fit AT rear end on 6MT car
  56. Oil pressure under 11 PSI " Hot" outside temp
  57. Help RE: G25 Issues
  58. Hello from Panama! Engine questions
  59. g37s vs G37 IPL rear differential
  60. TB Reset Procedure, same for g37 as 350z?
  61. 6mt question
  62. Stillen Oil Cooler
  63. Help P0021 & p0524
  64. Previous owner used nitrous
  65. 7speed issue
  66. Turbo Info
  67. Clutch HIt the floor and won't come back up.
  68. Help - Radiator fan always on
  69. 7AT valve body upgraders?
  70. Clunking when i start off from stopped, transmission mount?
  71. External Rear Timing Cover Seeping
  72. Concentric slave cylinder issue or clutch?
  73. What oil do you use?
  74. best radiator cap/hoses?
  75. LOUD noise when disengaging clutch
  76. Tunerz store legit?
  77. Stillen supercharger
  78. VDC completely off mod/switch
  79. Trying to understand the "Throttle Lag" issue
  80. 7AT - cooler line cut in location?
  81. low rpm struggling to accelerate
  82. Rpms dip/oil light comes on at idle
  83. 7AT Bad upshifts
  84. switching to synthetic at higher mileage
  85. 5-30, 10-30, 0-40 or?
  86. New valve covers?
  87. Failed HD CSC?
  88. First Stillen SC A-A Upgrade Kit - G37xs
  89. Help Engine shakes when the A/C is OFF !!
  90. Driver seat belt positioning.
  91. Help Exhuast manifold flange
  92. G37 LS Swap
  93. Transmission Problems
  94. Help Part broken. Can I drive?
  95. Can AWD exults fit on a RWD car
  96. Help! Metalic sound when revving.
  97. Twin Turbo Q50!
  98. Help Stillen Supercharger Belt's Part # g37 coupe
  99. Question about CAI & wet weather limp mode
  100. Urgent Help Needed
