- 2008 Infiniti G37S lagging
- Is there a DIY for Replacing Pulleys?
- Stillen Oil and Transmission Cooler & Autometer gauges
- Spark plug question
- Unknown adapter
- infiniti g37 '13 sounding like a diesel inside cabin
- Help Clutch Groaning When Cold: Bad Throw-Out Bearing or Old Transmission Fluid?
- Radiator fan assembly replacement DIY anywhere?
- Have you ever wondered about fuel pressure stability on the G37?
- Help A/C acting funny ever since I got the car
- Radiator fans always on, new FCM did not fix problem
- Quick Poll: Owners NOT having a vibration issue in Drive (D) while stopped...
- Grounding kit, does it actually work, where to buy and install?
- Bucking Issue 3,500 RPM
- DW300 Fuel Pump Pressure Problem
- Car temperature stays at H
- Help Installed Takeda CAI and it comes off
- W...T...F... is this rattle noise on cold starts?
- Auto Transmission Cooling Radiator - New Rad or not?
- Radiator Fan Upgrades
- car completely dead/ key fob not recognized
- Codes P0106 and P0725. Help!
- The Other Pressures we don't know
- Mysterious Coolant Leak
- Looking for info on cast intake options and opinions
- Blown motor?
- reverberation and vibration in floor/rear view mirror
- Acceleration problem
- The Other Oil temps we don't know...
- burning oil?
- This is just bad...
- Help NGK Platinum Sprug plugs
- Transfer case fluid level check?
- Easier way to remove thermostat?
- MAP Sensor Failure? Error code P0106
- Help Clicking from rear when putting car in drive, reverse, accelerating
- Help Twin charging vq37vhr
- Tune up gone Wrong
- Just pre-ordered DOC Race's new top mount kit
- Beeping issue when placed into park
- Single click, no start problem
- AWD Transmission Swap
- Help Hesitation and stumbling after not driving G for a while
- Rough idle and random shudder!
- '07 G35 Throttle body problem?
- Vibration in Drive (D) when at a stop. Also, idle in Drive (D)?
- 10' 7at Transmission Problem?
- 2009 - Code P0340
- Low oil pressure (P0524)
- Transmission shifting hard and lack of power
- RPM Issue With G37
- Erratic idle. What's in this photo?
- 2009 infiniti g37xS sedan code P0524 HELPP
- transmission year compatibility
- P0524 & P0021 Solved - Lessons Learned
- coolant /radiator issues
- G37 Hurst Shifter?
- 08 G37 ecu vs 2015 370z ecu - Uprev Flash
- Gallery Gasket and WaterPump Replacement Parts List
- 2JZ Swap N G37 Possible?
- Clutch Master Cylinder Tips
- 370/G37 Can bus system
- Blown Engine
- Stillen Supercharger Long Term Satisfaction/Reliability?
- Strange Rattling Frontend? Won’t Start Now
- PO447 Code EVAP Canister Vent Control Valve
- Changing Starter on 08 G37 Coupe
- Changing Air Bag Module
- Help G37 throttle sensor not being recognized
- Coolant Leak
- 2011 G37s 7AT code p0720
- Bigger injectors
- 09 g37 coupe wont starts
- P0345 and a Broken Camshaft
- Engine misfire
- Help tensioner pulley
- will a 2013 tranny work in a 2012 g37`
- Need Help - Low Pressure indication light came on
- Help P0011 & p0524
- Oem transmissible mount or z1
- Rod Knock- Crank/Bearing replacement how-to?
- Upgrade Rear Differential
- No acceleration after stopping for a few seconds
- Not going into park
- 08 G37S slow shifting, 5AT all gears
- P2096 SES Code
- water damaged engine
- My g37 idle is messed up (PO172 code)
- How do I remove the EVAP canister on G37s coupe?
- overheating while ideling or at low speeds
- Supercharger VS Turbo
- Help P0507 Code but goes away with AC
- Has anyone had a G37 engine swap?
- Throttle cut above 3500 - No codes
- Help Automatic stalls when put in drive
- Help 2012 G37X Engine Replacement
- G37 running on bad ps pump for 1mo
- Help P0335 - Crankshaft Position Sensor
- G is overheating
- Help 2010 g37x sedan problem
