- 7sp auto to 6sp manual swap in sedan - anyone attempt?
- G37 transmission
- Help 2011 G37 IPL Possible Clutch issue
- Anyone selling a stillen gen3 intake ?
- Help long.. shortblock
- Rear Timing Gasket and Elite Protection Plan
- Loose steering and shaking steering wheel help fam!
- Ultimate Z1 Header thread
- Rjm clutch pedal
- How long are cars kept AFTER turbo/super-charged?
- 100K service mark
- Low speed uphill stuttering
- Turbo VS Supercharger
- For all you rear gear swappers
- Shudder Noise Low RPM with South Bend Stage 2
- clutch pedal looses pressure ( new HD zspeed slave )
- 2009 G37x slow shifting
- Help Think I have a CSC failure, WHAT DO I DO!
- Help Stillen intake manifold removal
- 2010 G37S Clicking noise (like a relay) on gas pedal up and down
- Innovate AFR Problem
- 7 Speed Auto
- Oil on spark plug
- Car RPM stuck?
- Help Can't race my G .. Just 2000 rpm
- Hard shifts and stuttering at highway speeds
- 4.08s - quality of shipment. should I exchange?
- Help Looking for a clutch replacement that is daily driven friendly!
- Help anobody has any feedback on OBX LONG TUBE HEADERS?
- 2008 G37s with the follow aftermarket products
- Another catch can thread
- Throttle lag only while engine is cold?
- Help Stuck Clutch Pedal - Joining the Club PLEASE ADVISE
- Limp mode problem...
- P0014 p0024
- Stuck clutch pedal
- G37 7 speed automatic
- This light just came on, what is it?
- Gearing Calculator
- Help: Gearswap in 2 weeks...4.08s
- 2010 G37: A/C Not Cold When Idle...Intermittent
- Newer 6MT, hot weather, clunk clunk at low speeds?
- 7AT failure at 29k miles?
- My Plenum Project
- 6MT Drivers! Need your feedback please...
- Help Need help with emissions issue
- Getting new Converter from Dealer
- Piston broke inside engine
- 2009 G37x Sedan - Transmission Slipping
- RJM Performance Clutch Pedal Assembly
- Replacing clutch soon - what else should be done?
- GTR intake manifold conversion kit
- Noise coming from cold start on hot temperatures
- Shifter assembly replacement
- G37 automatic transmission in manual mode
- 5th gear noise
- 2013 G37x - Ester Oil vs Mobil 1 synthetic, Oil change interval
- I may have killed my G
- G37x Coupe VS G37 Sedan (Front Left Driver CV Axle)
- Slow downshifts/Grounding Kits
- Broken speed sensor bolt in Diff Cover
- G37X Service engine soon light on
- Motordyne G37 M370 Intake Manifold questions
- Help Need help with Front Diff 160A, Please
- ECU Swap (2008)?
- 2009 G37 Crankshaft Position Sensor
- iPhone AFR gauge app?
- OMG....did I just scarf my G37?
- Gear Swap-Possible consequences (ABS Etc.)
- Putting Power down in a 08S coupe AT
- Transmission Swap?
- G37 Wheel Bearing CPO
- 4.08 Gears....M/T housing...or no M/T Housing?
- Help Issue with throttle or automatic transmission?
- "Driveshaft Shop" Carbon Fiber Driveshaft
- Leak near Differential Bushing
- Kinetix Intake manifold
- Throttle lag after cold start
- Help Installed oil cooler and now P0011 code
- Seized rear wheels/ radiator cooling fan
- Help I need a Fast Intentions Shipping Box in LA
- Finally got to it - throttle body clean / grounding kit
- 7AT possible slippage/squeak.
- up rev help....
- Ordered - ARIAS forged pistons and Eagle forged connecting rods
- Exedy Stage 2 Clutch Kit
- Aftermarket clutch / RJM Assembly
- Help Cusco Front Strutbar & Cusco Rear 3-point Brace info
- Uprev question
- Anyone here try this bluetooth obd2 scan tool?
- No piping for Frozenboost Heat Exchanger
- Frozenboost - heat exchanger or front mount intercooler?
- engine problems with pictures please help!!
- Start-up Lag on 2008 G37 (w/video)
- Help Ark vs fast intentions exhaust
- Rattle and hiss noise...just put on exhaust
- Engine problems need help fam!
- Clicking noise speed increases with acceleration
- Review Diy ebay grounding kit
- CNC one-piece 7AT Flex Plate
