PDA
View Full Version : Engine, Drivetrain & Forced-Induction
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 [43] 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62
  1. 6MT shift knob removal
  2. G37 clutch adjustment
  3. Wavetech LSD vs. Quaife LSD
  4. Is stock HP quoted from the wheels or the flywheel?
  5. Best mods when staying NA?
  6. Tranny thoughts
  7. Help AFR Readings w/o Tune ... Safe?!?
  8. G37 Sedan Paddle Shifters
  9. Help Problem with my engine or tranny??? Expert advice please!!!
  10. Motul 8100 Eco-nergy vs 300V
  11. High coolant temp
  12. Slave Cylinder Failed :(
  13. Anatomy of a 4.1L 1200+whp VQ engine build
  14. Launch Control
  15. Rear Differential
  16. any of you guys herd of this? especially you san diego peeps.
  17. A few things- looking for answers
  18. GTM Stage 1 installed.
  19. car is losing power, when it's hot after spirited driving...
  20. TWM Performance Short Shifter with Knob
  21. Help Fast Intentions VS ARK Performance Exhaust ??!!??
  22. ECU / Programers
  23. Love the 7AT
  24. 7AT "learning"
  25. Help! B&M short shifter RATTLES
  26. Where to buy 4.08's
  27. FI GTM kits how long does shipping it take?
  28. doing burnouts possible in an auto tranny awd g?
  29. Anybody make a lower final drive ratio?
  30. Manual mode Neg Effect
  31. Help LSD Parts Question
  32. Tranny & Diff fluid change
  33. What oil is everyone using?
  34. My g's had its 4th master clutch slave cylinder replaced 4 times i need help plz
  35. Help OEM Clutch Replacement Recommendations
  36. VQ37 Internals.
  37. Rattling / Grinding Sound? Pilot Bearing?
  38. DS vs D and Range
  39. STS Turbo or GTM
  40. Berk or FI... which HFC is more resonated
  41. Sedan auto shift knob, anyone know the thread size?
  42. Help CEL P0420 Test Pipe / HFC - Non-foulers
  43. Are Short shifters bad for our engines?
  44. Shift Knob
  45. shimmering metallic material in oil
  46. My car sounded like a diesel truck, fixed
  47. what mph range should i be in?
  48. Help Clutch issue
  49. FREE PureONE Oil Filters
  50. switching modes
  51. question about the manual shifting (might be a stupid question)
  52. Adding oil between OCI
  53. Need installer in north jersey
  54. Anyone ever had the car transported?
  55. Manual Transmission Issues - is it done?
  56. Oil color is dark
  57. Oil Filters
  58. Help CEL p1148
  59. Help car won't start after transgo kit
  60. need my bearings replaced can someone give me info on this
  61. Review Stillen 20% under driven pulley review
  62. Uprev ecu questions
  63. Help Planning to go GTM forced induction: Questions
  64. G56S... is it possible?
  65. g37 test pipes fit 350z?
  66. 6MT noise?
  67. Stage 2 Supercharger Pre Release Test Drive Video!!!!
  68. Help Anyone with Nitrous using a progressive controller?
  69. Mazworx-GambitX Greddy TT build
  70. Cutting Resonators
  71. has anyone installed a stroker kit on the coupe?
  72. Knocking/Pinging on an 08 coupe
  73. Shiftlock (out of Park) is driving me crazy
  74. HELP! what colors for some hose in the engine bay
  75. Liqui Moly (Lubro Moly) oil
  76. All my dash lights came on.. what the dealer said
  77. madness after i installed the test pipes
  78. Oil Change Reset on Dot Matrix Screen
  79. Has anyone had any problems with the 7 sp auto tranny?
  80. Weird noise need help!!!
  81. g37 7spd trany reprogram
  82. DS mode & Highway driving
  83. Bad experience with NST
  84. 7AT - fluid temp vs. line pressure?
  85. quick turbo/ supercharger question about prolonged use
  86. Annoying 7sp transmission.
  87. Help Clutch Making WEIRD SOUND
  88. 7at... Wtf?!
  89. Na
  90. Long term affects of supercharger?
  91. NRG Catch cans x 2 installed!
  92. Hfc
  93. Goodbye Takeda, and R2C, HELLO STILLEN.
  94. Best clutch and flywheel
  95. HELP, car won't start - key fob de-magetized?
  96. Help Car came out of gear?? 7at!!!!
  97. AC Impact on MPG
  98. Transmission Issue!
  99. i got my uprev custom tune
  100. clutch question
