PDA
View Full Version : Engine, Drivetrain & Forced-Induction
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 [27] 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62
  1. Engine help
  2. another Ds mode question
  3. 2012 6MT Clutch issue.. more of a noise then issue
  4. How Nitrous works?
  5. Exhaust Size For FI
  6. Help Is it really worth it?
  7. Help HELP! {VIDEO}- Metallic Click/Clunk when shifting
  8. front diff and transfer case fill/drain plugs
  9. Shifting Issues
  10. Headers and HFC with Stillen SC - Which ones should I get?
  11. Anyone else notice car is more responsive with traction control off?
  12. High RPM downshift in DS mode
  13. ECU Tuning?
  14. oil for stillen supercharged G37S
  15. 4.08 Gear/Pinion Installed.
  16. Engine removal help
  17. Max horsepower for stillen supercharger
  18. Quaife differential - should I buy it?
  19. Help Question about Clutch, Pressure Plate, and Flywheel
  20. sold on a supercharger..performance fuel pump?? other things to support
  21. help .. catback
  22. Help 2012 IPL + stillen supercharger
  23. Bcm/ecu
  24. Engine pulleys upgrade
  25. G37x coupe backfiring
  26. Oil for the G37
  27. 2012 G37xS crack in engine timing belt cover
  28. Rough Idle Running Lean
  29. Changed plugs now my engine is knocking
  30. 7AT speed & gear "sweet spot"?
  31. M56 V8 Into a G37
  32. Forged ARIAS and Wiseco pistons/rods
  33. Help: boost, AFR, H2O temp guages
  34. Getting my modified transmission serviced at dealership
  35. clutch problems ( please help )
  36. 2010 G37 Sedan: Radiator Cap Stained
  37. Sluggish at higher speeds when warm
  38. Help Broken Part found during Intake Install
  39. G37 Coupe automatic transmission failure
  40. Broken clutch bracket
  41. car won't start troubles
  42. beluga muffler stock pipes?
  43. Amsoil Question
  44. Stock ECU HELP
  45. Additional cooling tips?
  46. Help G37 7at
  47. Whatcha think about Ethanol Free Gas
  48. g37 5 speed 4.08 differential
  49. Transmission Fluid
  50. Made a mistake letting Walmart change my oil.
  51. AWD engine into RWD car. What's needed?
  52. Any reason why my car would do this?
  53. code P0300
  54. 5 A/T drain and refill?
  55. Oil Pressure
  56. Transmission lagging question
  57. 2nd gear grind HELP!!!!!
  58. Battery issue? maybe...
  59. Low AT FLUID
  60. G37xS - AWD and Trans Questions
  61. Best TT Kits and Installers?
  62. rpm hang when shifting
  63. Sub 5 second g37 - what parts?
  64. Y and mid pipe with stock muffler
  65. HELP Car dies when put into gear
  66. lightweight flywheel chatter. fix??!??
  67. CSF radiator/Condenser combo G37 (AT)
  68. Taking the plunge with a blower!
  69. Review ***** AAM Competition's 370Z Twin Turbocharger System *****
  70. Input Shaft Bearing Replacement
  71. Mod Questions (The next step)
  72. Help Those with Okada plasma coils.. Photo attached.
  73. Dumb question about Tanabe exhaust
  74. G37 Starter and/or Alternator Replacement
  75. Help 6MT Stalling at red light
  76. Help Need Advice on Bottom End Build
  77. AWD Sedan stock OEM exhaust question
  78. 08 G37S throwout bearing rattle
  79. How To Drop The Motor
  80. 08 g37s clutch opinions. XTD clutch
  81. Safe Mode Issues: Violent Jerking
  82. Topspeed short throw shifter
  83. ZSPEC Ultimate Engine Fastener Kit
  84. Low RPM - car shuts off
  85. Installing rear axles back, answer this?
  86. GTM Turbo Kit
  87. Help Rear Gear Swap: 3.91 vs 4.08
  88. Gearbox not shifting to DS !
  89. rear end vibe on awd???
  90. Turbo/ supercharger 7sp A/T Question
  91. Help Bad gear shift at low speed?
  92. 2012 g37x sedan exhaust
  93. Rear Differential
  94. Definite & Concrete Tranny oil answers
  95. Transmission swap from 7AT to 6MT possible?
  96. Help Oil leak.
  97. magnaflow 11386 resonated x pipe
  98. Help Engine Cranking Weird
  99. Help Idle and tune issue
  100. ATTESA driving tips discussion
