PDA
View Full Version : Engine, Drivetrain & Forced-Induction
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 [13] 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62
  1. External exchanger for 7AT
  2. Help with speedometer
  3. Bogged down
  4. Transmission harsh shifting
  5. Easy DIY Starter Replacement
  6. Coolant disappearing
  7. Car started and stalled when warm
  8. Am I screwed? Limp Mode
  9. Code p0300 p0020 p0524
  10. Help Does anyone know what this rattling noise could be?
  11. Does the 2007 G35 or M35 has the infamous rear timing gasket leak problem?
  12. RPM jump and drop when putting my foot down
  13. Stroked VQ tuning issue question
  14. Help After WOT transmission looses its mind...
  15. need help - G37S no power under 3k rpms
  16. Help Sabb kit
  17. Stall after starting
  18. Starter Diagnose
  19. OBD4Everyone Video: VQ37 Top 10 Misunderstood Engine Sensors Explained
  20. Help is it possible that a faulty pump can cause error p0300
  21. P0011
  22. Help P0507: Idle surging
  23. 2015 q40(g37) rpm
  24. Help 2008 g35 sedan differential swap
  25. Pinging/spark knock?
  26. Will trans out help HFC install?
  27. P0021, P0300, and P0524 maybe not the galley gasket?
  28. 09 X Coupe Won't go over 1MPH
  29. Power steering not working, abs, vdc, and key dummy lights on? G37s 6mt
  30. Free play after a few miles
  31. P0300 misfire code / cylinders 1, 3, and 5
  32. Coolant Leak
  33. G37 coupe drivetrain swap
  34. How low will RPMs go at a steady speed?
  35. HELP!!! P1148 & P0031 codes
  36. 2011 g37x Time for a tune Up? Shutting off after start
  37. Stillen Supercharged 0-60 and 1/4 mile time?
  38. Looking for guidance after Dealer Diagnosis
  39. 2008 g37s ecu swap with 2009 g37s ecu
  40. Help Remote Starter
  41. Help Loud Grinding noise when clutch depressed in neutral
  42. Gallery Gasket - Is It Inevitable?
  43. Just Curious, Auto Trans Related
  44. Clutch Slave Cylinder failed -- Anyone recommend a shop/mechanic in Allentown PA
  45. Misfiring at idle
  46. '12 g37xs P0420 catalytic converter, need help
  47. 2011 G37x jerky acceleration/miss. No codes
  48. Help G37 2012 Shift selector slips into neutral while driving
  49. Turbo install
  50. Help Need advice on a clutch and flywheel
  51. How much play should I expect in the driveshaft?
  52. Help My 2008 infinity g37 seized
  53. Q40 transmission
  54. Water pump questions
  55. Coolant leak
  56. Replaced Diff Bushings and now my drive shaft vibrates
  57. Can you guess what clutch I have and throwout bearing noise
  58. Remus Throttle Responder for slow response?
  59. 2008 g37 P0011 code
  60. Car won’t shift!
  61. Help Differential Upgrade help!! 7AT
  62. Oil cooler and transmission cooler worth it?
  63. Intake manifold gasket replacement question
  64. Which oil for VVEL
  65. Help Soft Clutch Pedal in the Morning
  66. transmission question
  67. Misfiring 3,000-3,200 RPM - V36/G37 VQ35HR
  68. Engine quits right after starting
  69. PCV Valve?
  70. Radiator hose and clamp
  71. Intermittent loss of power, clears immediately after restart
  72. G37X Coupe Rear differential Noise / Vibration
  73. 14 6mt q60/g37
  74. G37 limp mode
  75. Help Vvel actuator bank 2 noise???
  76. Help 2008 g37s compression test and spark plug question
  77. 2008 g37s compression test and spark plug question
  78. Infiniti AWD & Manual Shift Questions (General)
  79. G37x
  80. High Mile boost?
  81. New clutch
  82. How to bypass p0420 and p0430
  83. Help p0300 ...please help :/
  84. Revolution sensor location
  85. auto shifter disconnected
  86. My g37s coupe
  87. Clutch life.
  88. 2008 G37 misfire (P0305) and ECU shorted out. Need some advice
  89. Transmission Update from Dealer?
  90. g37x transmission slippage with intercooler leak..
  91. No revers.
  92. Is This Good or Is There Something Better?
  93. Custom Grounding Kit 09 Sedan
  94. anyone have pictures of VQ35HR and VQ37VHR lower intakes?
  95. infiniti G37x 2012 where is the VVEL MODULE CONTROL located?
  96. Please help!! Urgent
  97. Dealership performed "driveline service"
  98. What is the difference between VQ37HR and VQ37VHR Pistons?
  99. Has any 1 heard of PCR?
  100. CEL Code Readers
