PDA
View Full Version : Engine, Drivetrain & Forced-Induction
Pages : 1 2 3 [4] 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62
  1. Help Transmission leak
  2. Engine coolant flush
  3. Got rear ended
  4. Help 2012 G37 Sedan overheating (blown head gasket?)
  5. Help Dual Oil Catch Cans with 3" intakes
  6. Help Limp mode and code P2101
  7. Help Transmission not shifting at full throttle
  8. Help Water pump/timing questions
  9. Syvecs AWD/4WD Controller
  10. P0524 after galley gasket fix BUT oil pressures are good
  11. G37 not starting. Battery new. Click sound
  12. starter problems - grind or whine?
  13. Help Bad Clacking Sound + Check Engine Light
  14. Paddle Shifting - can i do it all the time?
  15. Help for others with p0720, p0500, p0729-p0735, p1734 for 7AT
  16. Cai for a daily driver
  17. Help Car Won’t Attempt To Start
  18. Help Is ECU bad? Misfire on #1 went through the FSM
  19. HELP! G37X Passenger side Axle Seal
  20. Cam install diy
  21. Help G37 won't rev or accelerate
  22. Heater bypass for racing
  23. Will new Ethanol standards cause damage to our cars?
  24. Whole car vibrating at idle and when revving
  25. Help What rear CV axles should i be buying?
  26. Alternator Lifespan
  27. Help Power Loss and bad MPG after cleaning throttle bodies
  28. Anyone here boosted a g37x
  29. Help Manual Swapping my M56 - VK56VD vs VK56DE
  30. Help 115k mile '09 7AT - Recent slow shifts and "shift flare", drain and refill ATF?
  31. p1608 After washing car and filling gas
  32. VR30 trans in an x?
  33. Help Horrendous gas mileage
  34. Help Do I have a blown head gasket?
  35. Help Hum and whine from clutch
  36. Help Need advice on replacing flooded engine
  37. Help Power Steering Noise Can’t Fix
  38. Help Fueling questions
  39. Tuner - torque and traction control
  40. Help '08 G37 Coupe: Dashboard lights up but car wont crank or start
  41. Misfiring Cylinder - Engine Rough After Fix
  42. G37X Transfer Case Input Shaft Seal
  43. TERRIBLE mileage, reduced performance
  44. 2008 g35 vs g37 weight difference
  45. Bank 1 Short Term Fuel Trim Issue
  46. Help P2a00 & p2a03
  47. G37 won’t rev past 2200 rpm
  48. Lesson learned - don’t use cheap parts
  49. G37S - Clutch Hydraulic Failure Master/Slave
  50. G37 Clicking R to D, And D to R
  51. Sudden sputtering when accelerating
  52. Help Metal Chunks In oil pan
  53. Transmission died @ 75k in my 2013 G37x. How should I handle this?
  54. Throttle Lag/Hesitation when Hot
  55. Help With Test Pipes, tune or catted y-pipe for smell
  56. Passenger rear cv axle
  57. Lower Oil Pan vs. FUMOTO
  58. Help No crank, no start on G37
  59. Help Stock 2013 G37 wont rev past 4k, no codes, sounds different
  60. 2010 G37s Have Power, No Crank, No Click, No ODB2, ABS U1000
  61. Help G25x Humming Noise Not Wheel Bearing
  62. Aftermarket IAT Sensor relocation
  63. Manual Gear Position Indicator using Factory Gauges: Short Video
  64. My G37 overheats
  65. Check engine light for coolant temp sensor
  66. Help how do i determine what's putting my 37X in limp mode
  67. Frustrated after trying to replace clutch
  68. Help Replaced battery, car won’t start
  69. Limp Mode! Help!
  70. Weird noise under car
  71. High Idle no CEL
  72. Fuel temp sensor code
  73. PCV Delete thread
  74. Problemas con mi Crankshaft de mi g37 2009
  75. G37 Mini-Dash / Gauge Update... 16 pages & 35 data items!
  76. G37 delayed shifting
  77. P1574 ASCD vehicle speed sensor, P0500 speed sensor 'A'
  78. 7AT - Shift points normal or not
  79. Changed oil cooler thermostat from 185 to 200. No difference in temps
  80. Help Car will start then stall
  81. Spark Plugs
  82. G37 noisy radiator fan
  83. Z1 transmission mount installed and concerns
  84. Walnut blasting in NJ
  85. DIY Mini-Dash LCD Gauges Update #2 - New Layout & Multiple Screens!
  86. Debris in brand new Stillen catback?
  87. Help Filled up my gas tank and got 5 codes
  88. Oil Galley / Gallery Gasket - Worth it?
  89. Will the Nismo short intake work on the G37?
  90. Help P0430, bank 2
  91. Help 2005 g35 Transmission swap to a g37 2015 transmission are the drive shift same
  92. Help Car is starting and then dying + odd droning around 2k RPM's
  93. Z1 Oil Pan vs Greddy Pan vs Z1 Pan Spacer
  94. 2007 G35x sedan with weird electrical issue
  95. DIY Mini-Dash LCD Gauges Update
  96. What iPhone OBD datalogging app do you use?
  97. Rattling noise at idle in drive
  98. Exhaust Fitment/Rubbing
  99. Made a terrible mistake with Cat converters
  100. Review Tcm swap for auto trans
