PDA
View Full Version : Engine, Drivetrain & Forced-Induction
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 [36] 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62
  1. Transmission Oil Flush
  2. Manual Transmission Fluid Change
  3. Worth tunning with UpRev with HFCs/TestPipes?
  4. whirring, winding noise when shifting gears only at high RPMs
  5. new tranny + clutch replaced under warranty
  6. Clicking Sound from Engine Area
  7. whining noise when wheel turned all the way?
  8. Second transmission within 3 months
  9. For RWD Sedan, do you use D, or DS to drive?
  10. 2011 G37x engine stalls out when put into Reverse or Drive
  11. Trouble getting 6mt in Reverse after starting
  12. Transmission problem??? 5AT Sport
  13. My G Not going anywhere?
  14. What's the best clutch kit for our G?
  15. Shifter issues
  16. Won't go into 3rd in DS mode?
  17. p0300 missfire on g37
  18. Serious Engine Issue with my G37 (rod/piston?)
  19. Smart Accel Controller "Mod"
  20. 6MT - Hard going into gear. 1000 miles.
  21. Clutch Pedal getting stiffer, the longer i drive.
  22. G37X AT to MT
  23. Car Lunges Forward, Rpm rollercoaster, etc.
  24. Front timing cover
  25. How does UPRev Compare to say Kpro
  26. Alternator Woes...2009 Supercharged Coupe 7AT
  27. Engine sounds harsh during first 5-10 seconds
  28. Help Trans won't engage into Sport mode (5 AT)
  29. UpRev Osiris
  30. Carbon Fiber Driveshaft Group Buy??
  31. CEL but no code??
  32. Persistent Issues with Limp Mode - lemon?
  33. Help g37s engine knocking noise around 1300 rpms
  34. Help Question... How to tell if I already have an UpRev tune?
  35. Warning light problem
  36. Help Anyone get a CEL on a Fast Intentions HFC?
  37. Review RJM Performance Clutch Pedal... Yea, another one.
  38. Getting a uprev tune soon, a question arises.
  39. Aluminum driveshaft group buy
  40. Launching hard, is this wheel hop?
  41. Help Sudden RPM drop (video)
  42. No SES light with Motordyne ART Pipes
  43. Car Won't Start, Need Some Help Guys!
  44. Help Need help with exhaust!
  45. Alternator bearings
  46. 2009 G37S Coupe - Clutch Slave Cylinder issue
  47. Uprev fan control
  48. I hate the rev matching when downshifting!
  49. Engine warming up
  50. Block Heater
  51. GTM driveshaft
  52. 2008 G37S coupe timing chain replacement
  53. 7AT with Stillen SC kit
  54. Service Engine Soon light intermittently illuminated
  55. 370z AWD conversion
  56. Fast Intentions 370 turbo... What about us???
  57. 09 G37s slave cylinder Fighting Dealership
  58. Low level of engine coolant
  59. 2013 G Coupe 1200 miles Service Engine Soon light
  60. Help Disbalanced exhaust sound when cold
  61. Help Strange noise on cold start up
  62. Grinding noise coming from Transmission
  63. Help 6MT clicks and sounds. Am I the only one who hears changing of gears?
  64. Just bought an 09 g37s sedan 6MT. the assist spring was taken out. Need help!!
  65. Transmission
  66. Does this cause damage to transmission?
  67. new clutch, flywheel, hd csc = dead pedal
  68. Review Reality of a Dyno Tune>>>>> Stock ECU vs Hypertech vs UpRev
  69. 6MT Tranny Issues.......THIS IS NOT NORMAL!!!!
  70. 7at tranny slipping
  71. Transmission problem
  72. Clutch engagement Issue
  73. Sealed Auto Transmission life
  74. 17 inch Drag wheels
  75. Help Grinding gears. advice needed!
  76. Car Keeps Stalling
  77. GTM TT stage one question
  78. Dealership woes: Grinding Gears and Clutch Pedal stuck to floor Need suggestions
  79. Any tune available for 2013 sedan?
  80. Differential Swap
  81. Explain shift programs, sport mode?
  82. Best Tuner?
  83. Help loud clunk on a warm start
  84. Service engione soon light blinking
  85. Rev Limiter in Park
  86. 5AT fluid change?? How much?
  87. Reverse Gear on Manual Transmission
  88. RPM Drop While Cruising
  89. Throttle lag class action suit
  90. Help Code P0300
  91. 6MT Shuddering Woes
  92. transmission bang!?
  93. Getting Ready GTM 2SC
  94. Transmission Reprogram (7AT)
  95. Whining noise from clutch
  96. '07 G35 coupe - Mystery Noise Advise
  97. syncro issues?
  98. Gears Scratch/Grind When Shifting Gears
  99. Uprev Tuner in or around Kentucky??
  100. Help Weird issues transmission related?
