PDA
View Full Version : Engine, Drivetrain & Forced-Induction
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 [24] 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62
  1. Vr30 swap
  2. Oil pressure gauge
  3. P0420/p0430?
  4. PLEASE NOT ALREADY!!!! Transmission buck
  5. Can i mix new ATF with the old ATF
  6. Thinking out loud
  7. 5at limit?
  8. Help Stillen SC fuel and cooling issues
  9. Check engine light
  10. Oil filter thread pitch
  11. Help No throttle response in gear 6mt
  12. Infiniti G37 engine revs up and down randomly
  13. Built Motor vs. Nitrous Setup
  14. Power steering fluid in reservoir, circulation normal?
  15. RJM clutch adjustment question
  16. Help Stillen Supercharger post-install issues
  17. G37 coupe won't shift out of Park
  18. Paddle shifters help!
  19. Performance bolt ons- What to do next?
  20. Why doesnt my g37 bounce off redline like the 350z
  21. 08 G37s Cranks, Won't Start
  22. limited slip differential
  23. Warranty engine questions
  24. Anyone running a Catch Can Setup?
  25. Shift from 1st to 2nd with WOT
  26. E85 tune on g37
  27. Code po710, anyone dealt with this?
  28. Supercharger vs turbo/twin turbocharger discussion
  29. Exhaust smell
  30. clutch slipping on 3rd? G37s 6mt
  31. Loud Bang From Rear - VDC on
  32. CEL, rough idle, CYL 1 misfire still after plug change.
  33. Fuel Damper replacement
  34. Whats causing this sound
  35. 2009 G37X HELP! Seized Motor?
  36. AAM Competition Manifold
  37. Amsoil users, what's your Oil change Interval?
  38. Change Oil every 5k miles on G37X?
  39. Oil burning metal in plug
  40. driveshaft carrier bearing alternatives
  41. 2011 g37s map Sensor
  42. Help!! Mechanic Put 6 Quarts of oil in car!
  43. Manifold
  44. Stumble upon acceleration
  45. P1091, code set today
  46. 2012 Infiniti G37 Auto Transmission fluid
  47. Manual mode bog at redline? 7at 11'
  48. Help Engine Noise on Cold Start - Normal?
  49. 2012 G37x Axles
  50. Scangauge or ultra gauge
  51. is it safe to redline in every gear? g37
  52. Want to know your oil temp?
  53. Newbie wants supercharger, NEEDS HELP!
  54. G37 with 350z fuel pump module?
  55. Help Intermittient P0300 misfire
  56. Radiator cover
  57. 2009 G37x AWD coupe rack and pinion, remove and replace HELP
  58. Prospective G37 manual tranny buyer
  59. Vibra-Technics Motor Mounts
  60. AAM Competition R&D opportunity for AWD G Platforms!!!
  61. 6MT Gear Noise Normal? (w/MP3)
  62. Grey/Tan Film on underside of oil cap 2012 G37X
  63. Clutch problems HELP!
  64. 6MT Transmission noise
  65. G37x Coupe TT interest?
  66. Thermostat/cooling
  67. 6MT drivers with zero slave cylinder issues
  68. Help GTR spark plugs?
  69. Greddy twin turbo kit Thinking of selling
  70. Q60 coupe with only 2800 miles leaking slave cylinder?
  71. Remove rocker covers?
  72. 2009 G37S coupe stock not upshifting
  73. A Couple of rare mods would like your opinions with
  74. To people who use the Torque Android OBDII app
  75. 6mt Trans upgrade?
  76. New to Threads Diff Questions
  77. Feedback Please! Rear Timing Cover Gaskets/ Oil Used at Time of Failure
  78. 330+ whp n/a awd possible?
  79. blown transmission
  80. Help Anyone dealt/deals/heard of Boosted-Performance??
  81. engine swap compatibility
  82. solid state amplifier
  83. gtm turbo instalation .. help
  84. g37 gtm install problem ... help
  85. Help 2009 G37 engine ticking at idle
  86. downshifting on automatic?
  87. 6MT: Grinding 4th to 6th and 6th to 4th
  88. Miserable Coolant Flush ...
  89. g37s manual transmission oil change
  90. Ugh another failed Slave Cylender
  91. After FI HFC Install: P1168 Fault Code, P0037, P0057, P0031, P0051, P0130 Codes
  92. 4.08 gears & boost.
  93. Oil leak after an oil change?
  94. Clutch Slipping - Need replacement suggestions
  95. 2011 7 Speed AT Sport - Differential question
  96. transgo valve body
  97. Engine performance issues with 2009 G37 Sedan
  98. New transmission or TCM update
  99. Help Please Clutch/Transmission Issues on G37
  100. Engine performance issues with 2009 G37 Sedan
