- AWD Torque Splitter?
- Anyone Running HKS Type 2 BOV?
- Clicking noise from rear axles
- 7at in manual sport mode
- 2008 G37S 65k miles, Clutch stays de-pressed.
- Help (G37) V36 370Gt Low Frequency Pulsating Vibration Driving Me Nuts
- Engine rev when stepping on clutch
- Paddle Shifter Differences by Model Year?
- ECU Reset
- New Turbo Install
- Anyone here put a carbon fiber engine cover?
- 2008 G37 noise vibration from engine
- Do our car's hate winter gas?
- Help Fuel Tank Replacement
- 6MT Transmission whine
- Problem with G
- Can't get into gear after clutch change
- 2013 Engine to 2008 G37.. will it work>?
- Help Test Pipes/Downpipes
- I'm getting a new motor..... Mods?
- Engine stalled
- By-Pass Valve Upgrade for Stillen Supercharger
- Help Throttle lag on acceleration
- STILLEN Black Series Superchargers Now Available!!!
- Electric Turbos no longer a laughing matter
- Help: Bank 1 and 2 too lean error code?
- Help 11.1.14 Dyno Runs
- Wavetrac vs Quaife
- Second opinion? Mechanical over-revving
- Help replacing exhaust system.
- Idle air volume learn *FIX*
- M370 vs Z1 vs Stock
- Review World Record NA VHR Build
- Upgrade Drive Axels and Wheel Hubs?
- Issue with steering after backing up G37xS
- Help! Car won't go past 4K RPM
- Slave cylinder and concentric slave cylinder
- on WOT, sounds like water in fuel - but there isn't
- Clutch slave cylinder
- Aftermarket headers options for 6MT Sedan
- 6MT diff install progress
- Gtm stage 1 twinturbo kit issue
- Shift P Warning Problem
- Nitrous Oxide
- Oil Cooler
- Takeda intake quick question
- RJM Pedal and Still Have a Funky Clutch
- Clutch problem!
- Help Takeda long tubes does not fit sedan??
- Forced induction without a kit?
- Strange Clicking Sound when stopped
- Harsh downshift on hills
- New, Smaller Engines Coming to Infiniti - More Power
- Subframe bushing question
- South Bend Clutch Chatter
- First dead battery in 6 months of ownership of 2009 G37x
- Transmission mount
- Physics behind intake resonators
- AT Shifter Replacement
- 7AT Rear diff swap from non-Sport to Sport
- Spark plug questions
- Head gasket leaking at 31k and couple of other questions
- Help with Replacement Clutch
- G37 start up: Hit and miss
- P0106 back again!!!
- Transmisson Issue. HELP
- Diff vent tube replacement
- 09 G37s Coupe 7a/t Advice
- AT Shifter Assembly Replacement
- 19 inch oil cooler enough for supercharger?
- 2008 coupe s rear axle problem!
- Performance Mods!
- Warrenty fight begins
- My G37S coupe 6MT wont crank sometimes..
- Gtm breaking news<<<<must read before you even think of buying!!!!
- Are Whiteline diff bushings necessary?
- Bad News for MT Enthusiasts
- Need help please
- Anyone with 4.08 gears and 7AT?
- Acceleration (and Shifting) Problems, Need Help!
- What's the purpose of oil catch cans?
- Making 37s coupe exhaust louder while retaining the note? Also hks
- EV Conversion
- 2010 7AT problems?
- Review 7AT Manual Mode - A more granular review
- How do you adjust engine idle speed (automatic transmission)
- Help Shifting newbie
- Clicking noise coming from right rear tire
- 6MT: trouble shifting into first after driving for a long time
- Failing Crankshaft Angle Sensor
- Clutch pedal changes
- 4.083 too much gear, VLSD
- Check Engine Light..Not a Loose Gas Cap
- Do these cars' engines still have issues with burning oil?
- Review Dyno Runs- Maps from Motion Lab
- Rear Diff.
- Shifting gears in regular drive mode HELP!
- Help p0011 and p0300 ?
- ATTESSA upgrade??
- G37X Paddle Shifters
