- Ignition Coils - Suggestions G37 Sport
- 2008 G37 crankshaft sensor problems
- Bad clutch slave cylinder, should I replace the clutch as well?
- Strange starting issue and misfire
- Time for new Serpentine?
- Help Car Stalling in Drive and in Reverse
- Oil leak at rear timing cover
- Fuse for AWD->RWD
- mishimoto oil coooler
- 2008 G35X HFC install, now car hesitates
- P0011 + P0300 Confirmed. P0524 Pending
- 2012 G37s Sedan Won’t acceleration problems
- Help Anyone know what this plastic piece is?
- Gauge Pod idea for boosted G's
- G37 coupe starts and shuts off - HELP!
- G37X rwd conversion
- Rear Axle Replacement - Parts Options?
- Intake size question
- How much HP will these make?
- Engine Mount (Corroded?)
- Limp Mode/Transmission Violently Shifting
- Hard downshifts to 5th 7AT
- Alternator Concern
- P0340 code
- Intake manifold
- 2011 g37x wont start
- Mishimoto parts on sale
- Won't go over 20 MPH
- Help 2012 G37 struggling to start when been parked for 1-5 hours
- Help P1233 & Limp Mode
- Valve cover gasket replacement
- Awd transmission mount measurement?
- Help P0300 , P0524 , P0021 Can’t Figure it out ?!
- Can someone help me with my 2010 G37 Coupe
- 2013 G37 Transmission
- Help Motordyne Art pipe - Ceramic coating and wrap
- Oil gallery gasket
- Transfer Case
- Help DTC U0101 G25 Wont start need help
- G37 Sedan Metal Noise When Shifting Into Drive/Reverse
- Flashing 'Service Engine Soon' Light That Goes Away After 20-30 Seconds
- Timing chain guide and chain?
- Noise on cold start
- Car turned ON, lights on and makes ticking noise but won't start
- Help, new IPL owner
- 08 G37S Coupe Really Strange Case
- Radiator Fan operation questions
- Oil in 2010 G37 Sparkplug Wells
- Used turbos
- Whining noise when accelerating or slowing down
- Broken Intake Resonator
- Diffrential
- Help Driveshaft or Differential issue?
- Rear Drive Shaft - Clicking Noise - Normal?
- Help Drivetrain shudder/knocking!
- Leak from rear differential! G37X - HELP
- Help 7AT Compatibility
- Losing coolant, smoke and noise
- Help Timing assistance needed 2010 g37 sedan
- G37x coupe manual swap
- 2010 G37x rattling noise please help!
- Help Oil pressure light flashing but no check engine light
- Need urgent mechanical advice
- Poll: G37 7AT - low idle in Drive?
- Rpm boggs to 2000rpm
- Automatic Transmission
- PO734 error code and loss of power
- G37 help! Car shakes at idle
- G37x, delayed transmission torque when accelerating from stop
- Strange Alpha corrections divergence
- Misfire reading with torque pro app
- Idk what’s leaking but I need help!!!
- CZP Clutch, Flywheel, CSC combo
- Are the Intake and Exhaust Solenoid the Same Part?
- Help 1 quart low after 2100 miles
- 13 G37S randomly Slugish
- ‘08 coupe Z1 triple play (clutch, flywheel & CSC delete) input
- 7AT - draining all the fluid out
- Car in shop - getting worried......
- 08 G37 5 speed auto = g35 5 speed auto?
- G37 Transmission? HELP!
- Clutch (not pilot bearing) noise
- Is shooting flames bad for the motor
- G37 AWD CF Driveshaft
- 2013 7at issues
- Car wont start but radiator fans turn on
- Help Whining on Cold Start up Only
- G37 engine rattling noise after galley gasket repair
- How To Find a Short Running to the ECM on my 2009 G37X from the TPP Sensors
- G37 stuttering, shuddering, bucking at low rpm
- The Legendary Top Cat Bolt
- Is a tune required after installing a catback exhaust?
- Max rpm?
- Need some help with drivetrain issues
- Clogged cats?
- Gallery Gasket
- Turns on, engine won’t start, then won’t turn off
- Help Anyone know what this weird sound is?
- Engine swap info, help!
- Help Rattling noise when revving
