- Has anyone seen or used these fleabay oil coolers
- What's the best clutch for 2008 Infiniti G37s
- driveshaft center bearing
- 5AT fluid drain and fill question
- Just did Fast Intentions HFC Install, Have "Service Engine Soon" Keep popping up
- G37 Stillen Supercharger Vaccum hoses diagram
- Oil temp/pressure Sensor/gauge
- G37s takes a while to start
- 5 speed auto turbo
- Bore and Stroke: how was VQ37HR built up?
- Cliclking noise when accelerating
- Stillen Supercharger Swirl Jet step
- rpms surge after 5500 rpm while in a curve --2nd gear-tire slip or differentia
- Auto Transmission fluid change - Nissan is full of it
- What spark plug is good for Infiniti g37
- Help What RPM do you shift at?
- turbo or super charger?
- jerky autotransmission
- Intake hood Scoops. (Discussion)
- Broke my rear left CV axle where it goes into the diff.....twice in one week.
- Engine revs on upshift MT
- Change of clutch
- Help Sound coming from engine after Belt replacement
- Timing chain gasket blown, need help with part info
- Clutch Pedal Suddenly Squeaking
- removal of TB coolant return
- Momentum Headers For (DE)
- Question for those who have done 3.69 gear swap for 7AT?
- 2011 IPL Automatic Transmission Manual Mode Problem
- Help No start in misty weather
- P0106 / vacuum diagram
- Software updates
- FD Gearing / AWD Controller G37X
- Ams lightweight pulley?
- Help transmission
- Roots/Twin Screw G37x
- New Tuning Subforum!
- gtm stage 1 tt
- Transfer case was leaking
- Stillen gen 3 coupe intake
- BDE Motor Mounts? Thoughts, Reviews are welcome
- Oil filter adapter for a oil cooler that has pressure and temp sensor ports?
- Clutch failure
- Review Gamma motors
- Southbend stage 2 daily clutch with billet steel 19lb flywheel HELP
- Broken down and got a catch can(2)
- Thinking of turbocharging my g37
- Time To Say Goodbye!!!!!!
- shot a rod through the block =(
- 08 G37 Not Starting - Weird
- G37x Engine removal
- Difficulty shifting from park
- What does a bad input shaft bearing sound like on a 6mt?
- Engine hesitation?
- throttle lag
- G37S 2010 Coupe starting issues
- G37X Another bearing failure.
- which brand engine oil and filter you use for replacement?
- Oil around spark plugs
- 6mt installing a new shift boot
- 6MT Owners - clutch pedal too far away? Too short?
- Hesistant, sluggish acceleration at lower speeds
- MAF P0102 Issues
- Jim Wolf Cam testing for the VQ37VHR
- Do we have a low oil light warning for our vehicles???
- First Gear whine 7a/t
- Comments About The Onboard CPU
- 7AT remap ?
- Does the G37S sedan 6spd have a factory oil cooler?
- Coolant Leak - Hose? Coolant? or Something Else...
- Driveshaft Measurement 5-Speed
- Coolant Question
- Differential Fluid, Auto Trans Fluid Change Timing
- Smoke on startup, oil consumption fixed, dealership no help
- Can never get off the line smoothly...is it just me?
- So just how well does the AWD system work in the X models?
- CJM fuel return lines
- Automatics & Torque
- HELP!!! Limp Mode
- 7500 Mile Oil change intervals on Ester Oil
- Unknown Engine Trouble/Damage
- Help Is this Noraml Engine Noise?
- Gamma Motors Supercharger Kit for G37/Q60/Q40
- Eneos Differential Fluid
- Gear grind with clutch pedal fully in.
- Help OEM flywheel and clutch have a decent amount of rattle/chatter
- ECU and Transmission update by dealer, recommended?
- Closed Deck VQ (Block Guard)
- LSD swap questions
- Help Sport mode/ Rev match problems.
- Help How to know if I'm still tuned
- For my FI guys, worth the cost?
- G37x rear differential humming
- Uhhh... 4.08s = slower?
- Help Block Sleeves - When are they necessary?
- Cant accelerate fast without motor studdering.
- 2010 G37s Camshaft Issue
- Slave Cylinder went, under warranty but dealer is being shifty..
- 2008 G37S Coupe Transmission Failure (5AT)
- My automatic stalls and cant drive it!
