PDA
View Full Version : Engine, Drivetrain & Forced-Induction
Pages : 1 2 [3] 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62
  1. Car stalling issue
  2. Help 2013 G37 sport coupe won't start after sitting over a year
  3. Transmission and other upgrades in the past few months
  4. Help Is euro-spec oil okay for the car?
  5. P0720 code after transmission upgrades
  6. Help Intermittent Misfire and P0171
  7. Help Single Click/Clunking/Knocking Noise when I rev the car in Neutral
  8. High power on g37x sedan
  9. 2010 G37x 160k miles overheating boiling coolant
  10. Help Car cuts off at WOT
  11. Will someone measure the trans dipstick length plz?
  12. Help Drivetrain vibration/rumble when getting on and off throttle at 40+ mph!
  13. Help Hose blew off, don't know part
  14. Please Help me figure out my lean code since no mechanic will
  15. Help Are all g37 catalytic converter swappable?
  16. Help Hellcat supercharger on vq37vhr
  17. Help 2010 G37X - Limp mode + codes - Please help me!
  18. Excessive backlash in rear diff - is there a way to adjust it?
  19. Oil pan spacer on AWD G
  20. Dropping 7at for the first time
  21. Help Overheated, big bang, coolant everywhere, what happened?
  22. Help clunk sound when shifting in/out of reverse
  23. Help New radiator is mixing transmission fluid
  24. Driveshaft spacer
  25. Help RJM Pedal / Squeaky Noise
  26. Aluminum Valve Covers
  27. z1 csc delete problems
  28. Help Weird Front End Whirring/Howling Noise
  29. Help me Keep my G Alive!
  30. High Idle Issues
  31. Bank 2 VTC cam cover gasket
  32. Transmission upgrade options
  33. P0850 with shifting issues
  34. Z1 370Z Supercharger Tuner Kit
  35. Help G37 puffing noise from exhaust, runs when maf sensor is unplugged
  36. slight trans shudder on 2015 q60 awd
  37. Help Engine swap compatibility
  38. 6MT G37S gear shift problems
  39. Boosting the G coupe
  40. 2015 Q60S AWD engine issues after dealer service
  41. Losing coolant
  42. G falls on its face when taking off
  43. Bought a new awd but I noticed this engine has a cv axle shaft
  44. Help G37 Overheating
  45. 2009 g37s 6mt won't shift
  46. Any electrical experts in Socal?
  47. Help Concern over fuel pump assembly top hat
  48. Rattling noise and code (p0106) and TPS code
  49. Years affected by gallery gasket issue
  50. G37S 6MT with SRM from 370z Sport 6MT
  51. Test Pipe + OEM Donut Exhaust Gasket
  52. Help Low oil pressure
  53. How many shop hours for G37xS engine swap? (Any recs in WA state?)
  54. New EAC Twin Turbo Kit
  55. Help Erratic idle, misfire after warm up (158F coolant temp)
  56. Infiniti G37 Transmission Problem
  57. [Tutorial] Convert 3 inch intakes to include stock PCV system
  58. Very controversial topic: Oil Additives
  59. Help VVT solenoid
  60. Custom engine data display
  61. Help Mystery cyl 5 misfire
  62. Help Coolant in Spark Plug Well
  63. Help Odd limp mode or broken pedal?
  64. Help URGENT HELP w/Catalytic Converter
  65. Sputter after MAF/MAP Throttle Body cleaning and new plugs
  66. Motor compatibility
  67. FBO G37 on E85 - Max Power possible?
  68. Help Car keeps misfiring
  69. 370z Nismo Differential Swap
  70. Valve body dimensions needed
  71. Twin turbo kit for awd
  72. Help Replace Engine G37x
  73. Fuel system cleaner yes or no?
  74. Help MAF - Identify OEM vs Aftermarket
  75. Help Will a manual transmission fit on automatic motor?
  76. Help Low oil pressure after tear down
  77. $7k to fix a 2010
  78. 350Z HR Stillen A2A kit on G37 Sedan?
  79. Bank 1/2 retarded? Engine gunk
  80. Help G37 Sedan supercharger kit comparable to SOHO
  81. Help P0021 help please
  82. Help Engine rumbling at idle, running rich
  83. Help New Trans No Start
  84. Help Cylinder 1 misfire when up to temp
  85. Engine & Trans from 13' G37 RWD coupe into 13' G37X sdn compatibility issues?
  86. Consult 3 with p0106
  87. Help Grey clutch fluid out of bleeder
  88. Replacement Vacuum Line
  89. Help Swap to 6 speed manual from 5 speed automatic
  90. Help P0171 and p0300 code on g37
  91. High Idle and SEL light (P0305) during cold start
  92. Transmission Cooler for 7AT: Stillen or DIY
  93. What is this hose?
  94. P0335
  95. High mileage 7AT fluid change bad idea?
  96. Manual engine in an auto car
  97. AWD with built diff
  98. Help Bank 1 STFT problems
  99. Help Can't shift into gear with engine on (new clutch, CMAK, CMC, RJ pedal)
  100. Help Car slip light and BRAKE light coming on
