- IPL tune for G37
- Oil Cooler Q's
- Engine running rough after filter cleaning
- HELPPP with new NEW TSB for 7AT
- UK G37 gets 36.2 MPG
- Help Question about the MXP catback for my G37.
- HELP: radiator cap loose, limp mode?
- Non-FI Engine Build
- Putting radiator cover BACK ON?
- oil? on exhaust tip
- Anyone have z1 engine mounts, comment on noise?
- Review RJM AFP Clutch Pedal System
- Anyone try Seafoam?
- Help Edge Racing ? Anyone - Vendors Know??
- Help Car wont start!
- re-tuning your car?
- Birthday Present part II, Uprev Tune
- 2010 G37X Tranny
- 6MT Clutch?
- GTM Performance Engineering: VQ37VHR Engine Build 700HP Power Package
- Weird idle noise????
- Unorthodox Racing Pulleys
- GTM Performance Engineering: PROJECT VQ42VHR S/C
- ProKit today, Z1 Tomorrow!
- Help Recommended Uprev Tuner On East Coast w/ AWD Dyno?
- Uprev tune, check the results!
- ECM replacement for all Infiniti models later than 2004
- Driveshaft Installation Help??
- Uprev or Cobb?
- Want a G37xS need more info
- HELP !! Shifting lag on g37
- Time To Replace Transmission :( is 5AT to 7AT possible ?
- K&N drop in filter not snug?
- Strange problems - Tell me what you think
- Anyone use - Mobil 1 Gear Oil LS 75w/90 For Diff / Tranny?
- Very nice differential & LSD illustration
- For you automatic guys!!
- car is shaking and feeling like it gonna stall anyone know?
- Anyone?
- Stock clutch question
- Help Recommended Brands of Headers?
- Z1 Motorsport Driveshaft B4 / After Dyno G35
- Clutch Master Cylinder <----Sucks
- G37 Sedan - Fast Intentions or Berk HFC's?
- Changed oil tonight...old oil smells like gas?
- Help Strange Shifting Issue with 08 G37 Coupe 5AT
- grinding/scratching sound when switching gears
- Help Benefits of underdrive or overdrive crank and alternator pulley
- Did I just get screwed v2
- D vs. DS vs. M
- I have some questions!
- UGHHH P2A03 gremlin i cant figure out!!
- Does anyone add any fuel system cleaners in their car?
- Why no AWD manual transmission?
- Samco hose kit. Which clamps are you using?
- 2008 G37S clutch question
- Help Mid-Pipe Dilemma
- Super G 530hp twin turbo V6 in the pipeline?
- E85 tune
- CF Radiator Cover HELP!
- 12 g37s feels slower than same year loaner?!
- please help me , I install stillen gen3 intake my car too lean !!
- VVEL tuning
- FI Guys
- Help Axle issue I believe
- camshaft installation?
- G-Force Chip
- 7AT Wont Shift into gear
- Help Question on Cat Converter
- 5 speed auto not staying in DS mode- HELP!
- another low/poor oil consumption thread
- First CEL Light
- Hypertech ECU
- Trans and Diff fluid
- IPL + Stillen Gen 3 + Tune
- Oil Pan bolts Help/question
- Stillen Gen.3 intakes
- Does this dyno number seem a bit much??
- Miss my Corsa
- Need advice!
- Cheap and easy performance upgrade recommendations???
- Stillen Super Charger or Twin Turbo ?!?!
- E15 Gas
- Help 2008 g37s has issues with reverse
- Help Engine Codes P0345 P0335 P0340
- Go Kart Catch Can Install
- Help P0300 Code after Berk HFC install **Help!**
- Help Problems with VDC
- Need your ears, does this engine sound normal?
- Help Quaife LSD Question
- Proper interval to change atf for 7-speed auto
- Fuel Smart
- Raddling noise from 6mt
- Manual transmission issues?
- Help 2012 G37 Coupe: Intake/Exhaust/Coils?
- G37 coupe exhaust rattle (no warranty)
- Building a 1000 HP G37
- Octane Question
- Oem 6speed flywheel
- 7AT - *sigh* - Time for the dealer?
