- Oil - Thinking of switching - Mobil 1 or Pennzoil Ultra
- UPREV Osiris Standard E-Tune ? Anyone done this ?
- ART, XYZ, HFC, and a tune.
- Ignition advance with Cobb
- how good can this turbo be?
- ARK Exhaust on the way!
- G37 gearbox issue
- Why no one is bragging about their new Takeda??
- My Dyno Results
- Serpentine belt under warranty?
- Flange for limited slip carrier?
- INTAKE INFO, I'll PAY FOR
- Looking for the best/popular intake and exhaust
- Engine died 09 g37x coupe 7400 k miles
- Got my NST pulley's today
- cold intake size???
- Help Question!!
- check engine light came on and car wouldnt move.. very strange
- Gas milage with GTM SC
- got stuck in tiptronic for 10sec
- No Ester Oil available!!
- Just Ordered... part 2
- Help Need advice on hypertech + exhaust
- Base line Dyno
- Getting new motor at 60k
- VLSD markings
- Transmission problems exclusive to 08 models?
- Help Berk Technology is looking for your car
- Questions about my new G37
- Got $3,000 To Spend on 2008 G37 Coupe
- Aftermarket Clutches for stock flywheel
- G37X 7at Issue, no its not flare....
- Gaskets on Front diff and xfer case
- Stock different broke, new OEM Diff is Different!
- GTM Stage 2 Supercharger Preliminary Testing Results
- Just ordered..
- Dirty Rear Differential Fluid?
- Changed the oil today
- Spark plug recommendation & life
- ne SC or TT tuned G owners here?
- **FREE** Case of Valvoline VR1 Racing Synthetic Oil
- Forged Performance: Bolt-on G37 Tuning
- Loud chatter noise
- Review 4.083 FD Rack and Pinion Gear
- Help Idle issues, please help!
- Bad slave cylinder again
- Anyone Know What Temp Sends the VQ Into Limp Mode?
- premium or regular?
- Serpentine belt
- Stillen Gen 3 vs Takeda Single CAI
- True Dual Exhaust
- G37 S Idle Issues
- Normal to grind into second near redline, or did the prev owner bork my tranny?
- 6MT grinding into 6th
- Meisterschaft exhaust G37X
- Shifting Without Using the Clutch
- Car doesn't recognize I'm in park
- Front bearings/seal on fairly newish G37X, waxy stuff and rust? pic inside
- Windshield washer bottle relocation after GTM supercharger install
- GTM supercharger video
- transmission issue?
- What's the current story with the 7AT???
- Nitrous Express kit INSTALLED
- Gonna instal some light weight pulleys, let me know if this would work
- Spark plug question
- Need some serious help understanding final drive ratio
- Osiris Standard?
- Anyone with bigger radiator?
- Your opinions between SC and TT..
- Anyone ever got their transmission replaced by Infiniti????
- Transmission additives?
- Shifting on 2011 G37XS
- Hfc + injen cai wot smell
- Clutch Chatter (Video)
- Best place to buy an OEM clutch?
- Which model gets Paddles?
- Help Where would you go??
- Help Supercharger on 2008 coupe auto tranny?
- tuning the Intake valve timing control?
- What's the best way to get around 400 hp the cheapest way
- Question Regarding Holding Clutch In
- 08 6mt clutch issues?
- Throttle Body Spacer
- Clutch replacement
- STOCK MOTOR: Highest Nitrous Shot?
- VQ37VHR Harmonic Balance
- Good Experienced Cobb tuner in Southern CA
- Coming soon Berk Technology Cat-Back Exhaust System
- Help !! Stripped Cat Bolt !!
- What is up with the 6MT Sounds?
- whiney engine
- R2C on '11 G Vert.
- Horsepower claims
- Review My ongoing ExoticSpeed RII-Titan PWR exhaust review
- 30K 5spd auto tranny flush and fill
- Radiator Overfill Tank
- Royal Purple + other fluids/mods
- Cobb ECU plug HELP
- Help with Cobb AP
- Magnaflow Catback exhaust system
