- Best silicone hoses
- car shuts off after start
- 2010 G37xs P0011 P0340 P0123 P0223 P2101 U0101
- Help Engine oil g37s?
- Need Help Locating EOT Sensor
- Fast Intentions 370Z Oil Cooler On G37
- Help Engine holds RPM after rev
- Help Thoughts on this spark plug?
- Head gasket leak?
- Help! Clicking after Diff upgrade
- peddles shifter
- Diff swap 5at 350z to 4.08
- Black Friday Sale on Short Shifters and Shift Knobs
- 2008 G37s won't shut off
- Crank pulley out of balance.
- G37 vs 370Z radiator/condenser
- Installed dynamics injectors 725cc on a stock G37
- Transmission and engine serial numbers??
- Help Car Wont Start After ECU Reset
- How can i get as much air in my engine with out turbo just bolt on's?
- whats the right fuel pump for 725cc Dynamic fuel injectors?
- Uprev obd2 with app
- GTM 1.5 Supercharger Kit question
- 11.2 1/4mile custom rear mount turbo
- Check engine soon light only on when engines off?
- Is there a way to check transmission fluid?
- Question on tranny fluid filling 7AT
- Any consequences for driving in manual mode and constant downshifting?
- RJM Clutch Pedal, then slipping
- Help Rear diff fluid?
- Help How to remove P0430 after aftermarket exhaust
- P0021 code not going away shaking like crazy
- E-Charger Hybrid System
- How deep is too deep?
- Motor mount replacement
- Spark Plugs
- Stillen supercharger install
- Checking Coolant level.
- G35 5AT trans in a 5AT G37?
- camshaft and crankshaft sensor location?
- No Response from Level 10 TRANSMISSION
- New October STILLEN Promos!!!
- Car losing power
- I need advice
- Final drive gears
- Transmission issue?
- Engine Stumble turned into Loud Noise
- 2010 g37x VVEL p1093 help
- Help with custom super vortech build
- Service engine soon light came on code is P0106
- P0012 to P0081
- Help P1233 after throttle body cleaning
- My G37 stalled on the freeway today. HELP
- Z1 HFC vs FI RHFC vs others
- A/T Transmission Failure?
- 'Rough' idle after bolt ons / Build thread
- Anyone feel a real difference when you changed your spark plugs?
- Clutch Bleeder Screw
- Ticking/knocking from engine bay at 3k rpm
- Help! Clutch Problems
- Rear subframe bushing
- Driveshaft for 2011 7AT Journey
- Help My acceleration is messed up! 2013 G37x.
- G37x Engine & Transmission
- Gear whine near 85 mph
- Supercharged and MIL bad CAT codes
- Knock sensor pulling timing
- 370GT acceleration lag, bogging down.
- short shifter
- test pipes??
- Heater hose replacement: Cost? Coupler fix?
- 70K too early for spark plugs?
- Help transmission grind
- HFC vs Test pipes
- G37 coupe acting up. PLZ HELP
- car start up
- Throttle problem
- Starter, Battery, Relay??
- Help Replacing my starter
- Forced induction
- G37s 6mt bogs
- Help Loud ticking/knocking under car after revving (video)
- Help Ark makes headers?
- Weird noises + dealer woes.
- Front RH axle shaft keeps tearing
- Clutch master cylinder bolt thread size?
- Clutch master cylinder BS - vent
- Fluid leaked out trans.
- New clutch possibly?
- Help Finding Paddle Shifter Kit for G37 Sedan
- '11 AWD sedan rattling and vibration in front end
- Relay question
- Accidentally put in regular instead of premium
- Engine Burning Oil?
- Will the engine from the Q50 work in a G37 sedan?
- Those familiar with vq timing.. feel free to come insult me
- G37/370Z 7AT FAQ Mega-Thread
- Who boosts their octane regularly?
- Clutch Fluid Gone.
- 7AT Any way to downshift by pressing shift knob foward?
