PDA
View Full Version : Engine, Drivetrain & Forced-Induction
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 [37] 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62
  1. P0174 Code
  2. revving to redline in neutral
  3. Are our throttle bodies always full open?
  4. Shift boot loose and now creaks?
  5. Help K&N Filter and MAF
  6. Car wont go past 30-40mph
  7. Ticking noise after turning off engine
  8. Info needed for Nitrous setup
  9. Defective Driveshaft
  10. Learning ECU + Highway Driving?
  11. Limp mode
  12. Who has a GTM Twin SC Installed
  13. New GTR Tranny in my G37
  14. Catch-can
  15. Service Engine Soon light with 800 miles?
  16. Clutch slip 2008 g37s 6mt
  17. Review Hill's Garage GTM Stage 2 Supercharger Direct Port Methanol Dyno
  18. transmission problem? Please Help
  19. 7AT power handling
  20. brake light
  21. Help Car almost shut off while driving?
  22. how to add coolant?
  23. Help Boom`
  24. Those w/ custom tunes; Rev limiter setpoints?
  25. RHFC Rattle fix?
  26. Dyno Tune Shops in IL??
  27. rev limiter & uprev tune
  28. I need to push the Push Start button 3 times to start my car!
  29. Help Will G37 flywheel fit 08 (HR) 350Z?
  30. RPM spikes for no reason
  31. Cold weather oil - do you switch to a different weight?
  32. Help Vibration
  33. G37 with dealership. Transmission replacement.
  34. Slave, clutch, and flywheel
  35. Help Won't go into 2nd Gear
  36. Sprint Booster
  37. Car won't start.... battery????
  38. Help Weird Breaking issue (Video)
  39. 1st gear slipping?
  40. 7eat reprogram for faster shifts?
  41. throttle sticks at 2k rpms??
  42. Smog time for 2008 Gs in California.
  43. Weird whining noise.
  44. Help Bizarre transmission behavior
  45. Noises!
  46. Clutch Rattling
  47. New to the G37 family..
  48. aluminum drive shaft
  49. VDC & slip light come on under light acceleration and remain on
  50. Royal purple max gear
  51. Help Which harness is the O2 sensor part of?
  52. Flushing tranny oil on 6mt - which to use
  53. No air relief plug on heater hose - can't bleed cooling system
  54. Service Engine Soon
  55. for those looking for 15whp
  56. WTB - VQ37VHR engine for 2009 awd
  57. Slave/Master Cylinder Out
  58. Shifter Rubber Boot
  59. R&R transmission fluid . . .
  60. 70K on SC'ed motor?
  61. Thinking of buying '13 G37 6MT. Clutch questions...
  62. Help Stillen Charger for supporting mods
  63. Help Z1 Oil Cooler + Amsoil Bypass Filter
  64. VVEL unlocked!
  65. Help Idle drops
  66. Damage or protection!? Clutch/transmission/vdc
  67. FI Rattle?
  68. Did i damage my engine.
  69. used stillen s/c kit
  70. Question - What is the latest Transmission firmware for G37 2011 Sedan?
  71. Software CONSULT tool - anyone used this?
  72. Serpantine Belt
  73. For those with 7AT smoothness and driveability issues
  74. Help Timing chain or starter motor-video included
  75. G37 engine noise under hard acceleration
  76. Will G37x ever have a manual transmission?!
  77. Help STILLEN LIGHT WEIGHT pulley
  78. information and details to lighten
  79. Help Methanol voltage controller
  80. Help Tune in nj????
  81. BIG mistake with ECU reset!
  82. Uprev cooling Fans control
  83. UpRev tuning question
  84. Help Any DIY's for Valve Cover Removal 08' Coupe?
  85. Clutch acting up in hot temperatures
  86. clutch slipping
  87. Review RJM AFP review..another
  88. IPL exhaust pipe size
  89. engine salt
  90. Need help with MXP exhaust!
  91. g37s 6MT tranny question..
  92. Dyno Tune ??
  93. New Clutch - ACT site doesn't list G37
  94. Help AEM Dryflow filter replacement for Stillen Gen 2 intake
  95. Going Hybrid
  96. Bellhousing question
  97. Service Engine Soon Light?
  98. Padlle Shifters on my 2010 Base G37 Sedan
  99. 09 G37 tapping after oil change....Help!!
  100. Oil cooler question
