PDA
View Full Version : Engine, Drivetrain & Forced-Induction
Pages : 1 2 3 4 5 6 7 [8] 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62
  1. Stupid oil filter
  2. Nitrous good or bad
  3. Maintainence & Detailing meets Fate
  4. Full intake cleaning
  5. Help Cylinder 6 Misfire
  6. Opinions on Z1's Clutch+Flywheel?
  7. G37 rattling noise - help!
  8. Help Identifying engine leak
  9. Are the Engines Interchangeable?
  10. Tune or no?
  11. G37 Coupe Automatic Shifter Not Working
  12. ATF Change Experience
  13. g37 engine knocking noise around 1300 rpms
  14. Help P0603 - powertrain error
  15. Thinking about switching to Rottela
  16. Vehicle Enters ACC Mode but Wont Turn Over
  17. Need to replace my clutch
  18. Trying to get the OEM ignition coil, need help
  19. 2012 g37x tranny cooler line nightmare...
  20. VQ37 / 7at questions
  21. G37 rear main seal question
  22. Recommended 6 speed manual transmission oil?
  23. Help RJM Clutch Pedal
  24. Atf fluid
  25. Help Another Random Misfire Question
  26. Oil change advice for g37 coupe ith 100k miles
  27. Help Ect sensor
  28. G started to burn oil :(
  29. Help Paddle shifter wiring
  30. OBX Helical LSD
  31. Help Does this sound like my starter is sticking/not disengaging?
  32. P0300 only on cold start up
  33. 2009 Infinity g37’s coupe clutch kits HELP!
  34. Gas Mileage Varies/Low 2012 G37X + starter issue
  35. Engine compatibility
  36. Z1 Diff Cover
  37. Random limp mode
  38. Transmission dipstick
  39. Help Engine RPM stutters/hesitates/jerks while accelerating
  40. Pulsing revs when engine cold
  41. Help please - Transmission issue?
  42. 2010 G37 Coupe. Ticking/Clicking noise
  43. Clicking sound (rattle/shake)
  44. G25 2012 gcc
  45. VDC, SES and blinking cruise
  46. Help! Won’t turn on any more
  47. Paddle shifter
  48. To make a G25 fast...
  49. modificatios/Stillen supercharger/exhaust/
  50. Please, I need help. For the love of God! lol!
  51. Help - What part is this?
  52. Thaitanium Dual Resonated Test Pipes
  53. Timing belt question
  54. 2010 infiniti g37 journey
  55. Help Transmission slipping 09 37x
  56. During WOT car shows key symbol and goes into DS???
  57. Help Engine hesitation, slow acceleration and knocking
  58. 2009 g37xs stillen sc
  59. Bad MAF vs. Vacuum Leak
  60. Broken Axles
  61. G37x sedan problems
  62. WOT below temp safe mode?
  63. P0725 error code and U1000 code 2009 G37x
  64. G37S 4WAS power steering pump interchange (pics)
  65. Transmission coolant line question
  66. Help for P2101 on 2010 sedan
  67. Car pops out of gear after hard stop 7AT
  68. Little help with operationing temp
  69. 700-800HP Goal Forced Induction or engine swap
  70. Help! Coolant leak but no overheating
  71. Empty Clutch Reservoir, Seeking Advice
  72. 2010 Infiniti G37s convertible P0340 code. Stuck in limp mode - Help!
  73. Help Clutch fluid leak
  74. Help Vibration while stopped in gear
  75. Engine compatibility
  76. Changed Spark Plugs, Car Runs and Smells Bad
  77. Any tips after swapping new 37vhr motor?
  78. Constant Issues with 2009 G37
  79. Help Going to be changing my engine , what do I need ?
  80. Oil temperature sensor not working
  81. G37s power loss at launch
  82. 2012 G37x going into limp mode
  83. Misfires and Engine Vibration at Idle
  84. 2012 infiniti g37 ECM
  85. Brake light flash and VDC stays on
  86. P0021 p0524 p0300 after changing galley gasket
  87. Amsoil MTF vs Redline MT85
  88. Car starts to Stutter at 2200 RPM and wont go higher
  89. Squeaking noise when AC on
  90. Help!can’t find the reason of coolant leak
  91. Help Orange puddle under car
  92. Help P2A03 issues!
  93. Help Leak - expected repair cost?
  94. Help IPL Spark Plug Advice?
  95. Help Water pump or possible other issue?
  96. P006a code
  97. Help All electronics dead when I enter car
  98. Help Automatic Transmission wont allow manual shifting
  99. Transmission upgrade?
  100. Can anyone read this?(numbers from code reader)
