PDA
View Full Version : Engine, Drivetrain & Forced-Induction
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 [54] 55 56 57 58 59 60 61 62
  1. x-pipe
  2. My brothers G35 (las vegas)
  3. Oil analysis on Eneos
  4. HELP: CEL Codes P1148, P0031
  5. Oil check question
  6. Cobb AccessTuner Race Tuning Thread
  7. DS Mode Issue
  8. Switched 6MT fluid
  9. Some pictures of my Nitrous Express Install - VQ35HR
  10. Hamp oil filters
  11. Megan Racing Axle back exhaust?
  12. Car shut off after initial Start-up?
  13. What dealership did you go to for the TSB Transmission fix.
  14. Opinion on Transmission Cooler
  15. RB26DETT swap - is it possible?
  16. Engine Control Unit being Replaced
  17. Help Rev sound change after 3k RPM
  18. Is it worth getting a Cobb AP?
  19. AccessTUNER for Nissan/Infinity available NOW!
  20. Found a way to deal with the 7AT issues…
  21. The transmission doesn't downshift and stick at 4000rpm in DS mode
  22. Harsh Downshifting - anyone get the TCM update?
  23. How can you be sure that the dealer put the oil you specified?
  24. 7AT Lurches when slowing, normal or problem?
  25. G37 Transmission Issues with 4th -> 3rd Downshift
  26. Threw my G on the DYNO ... results..
  27. Car Running Rich!!!!
  28. 6MT clutch question.
  29. Cobb in Plano, TX Offer
  30. Grounding Kit question
  31. Rasp Question
  32. 5k rev limt?
  33. Synthetic in Read End?
  34. SES Light Second weekend in a row
  35. Aftermarket LSDs?
  36. Time for an oil change?
  37. Engine Increasingly Noisy
  38. What is your RPM at IDLE on G37X ?
  39. TT kit for G37x?
  40. I miss having an aftermarket exhaust, its been about 3 weeks of having
  41. transmission problem
  42. How does DS Mode work?
  43. Oil and Transmission Cooler Anyone?
  44. 91 fuel completely necessary?
  45. Question about MPG and Mods
  46. i think i got a trans problem
  47. Clutch assembly+fly wheel replaced under warranty plus extra stuff I had
  48. New transmission?
  49. B&M Short Throw
  50. Help Service Engine Soon, car won't start
  51. rev hang and slow throttle response
  52. New G37 Owner - When to do first oil change?
  53. Any progress on ECU's for 09 Sedans?
  54. Insurance question
  55. QX56/Titan 5.6L V8 Engine swap Q's
  56. Has this noise been identified?
  57. Do you shift yourself or let the car shift automaticaly in break-in period?
  58. MXP or HKS ?
  59. Why the hate for Stillen Exhaust?
  60. Shift knob not in park?
  61. In need of help from 7AT Owner’s
  62. Slow Transmission (if that makes sense)
  63. What is the standard oil Infiniti uses
  64. Did you know our factory Air Filter is Oiled?
  65. is your new g37 use oil ?
  66. Blown Engine and Trans
  67. Cold start Dash/Vent Noise
  68. Does it smell bad when you ride the clutch??
  69. For those with Berk HFC's, Questions
  70. New poster/G37 owner. Q about oil.
  71. 1st - 2nd DS mode
  72. How to use Manual-Trans Mode for G37-RWD-Sedan?
  73. Service Engine Soon light...
  74. GT Motorsports: GTM Stage 2 TT G37 Coupe, GTM 3" Cat-Back, GTM Flash, 611RWHP/47
  75. Need help for choosing the rite exthoust!!
  76. plenum spacer from tekeda?? Video???
  77. Help Torn between two exhausts...
  78. how to disconnect car battery
  79. Engine management suggestions
  80. Wierd Downshift Issue ('09 G37 Sedan)
  81. 6MT came out of gear while driving.
  82. Need a good Jump starter
  83. B&M Short Shifter inquiry.
  84. GT Motorsports: GTM Rear Differential Cooler Kit
  85. Problem with the G
  86. When to replace the G's ignition coils?
  87. "Engine Service Soon"
  88. Help Help please
  89. Friend said i should insure turbo / engine?
  90. Auto Transmission mod
  91. Help Switching back and forth from one type of oil to another?
  92. Help 6th Gear Grind
  93. Help Grinding on 3rd?
  94. Automatic to Manual Transmission
  95. HFC's for CALI G Owners
  96. State w/ No Emissions
  97. Review Say hello to my UR Underdrive Crank Pulley
  98. Shredded Serpentine
  99. Motul 8100 Oil
  100. Help DTC code
