PDA
View Full Version : Engine, Drivetrain & Forced-Induction
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 [31] 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62
  1. Accidentally spilled coolant on serpentine belt!! now screaming!!
  2. G25 Intake on a G37??
  3. Review Support Matrix????
  4. transmission problem
  5. P0106
  6. Reversing the shifter on a G37
  7. Battery dies intermittently, key fob says its low, much more
  8. Engine choking at acceleration after 2k RPM
  9. Help What is the meaning of 'slip'
  10. Transmission Issues - Need Help
  11. Help 6 speed reverse problem
  12. Rusty clutch bleeder valve
  13. Transmission Problem?
  14. Review Motion Lab-E TUNE
  15. Exhuast question
  16. Error code... Ideas?
  17. Help Need Help With My Engine!
  18. Need Help With My Engine!
  19. Loud injectors/valvetrain on '10 coupe
  20. '09 Coupe w/ 90k - Problem with ECU/ECM?
  21. check engine light
  22. catalytic converters
  23. Help how to change the maximum engine speed of VQ37VHR
  24. Cosworth Oil Pump.
  25. Broken piece in engine bay?
  26. G37 Paddle Shifter installation w/ pictures
  27. weird "vibration" while stopped. help!
  28. R2C's installed
  29. 6mt Drivers, do you feel vibrations when pressing the clutch?
  30. Anyone running 3.90 0r 4.08 diff gears supercharged
  31. Is it bad to replace the engine air filter early?
  32. Help Please help guys: will pay
  33. LSD in non LSD
  34. Clutch Safety Sensor?
  35. UpRev question
  36. Help starting issues stillen supercharger
  37. HELP Auto Transmission Problem!! 2008 coupe
  38. UpRev - Cooling Fan Settings (radiator)
  39. Start button issue?
  40. Throttle Body Whine and Click Noise
  41. Manual shift issue
  42. 7AT Wont Rev Match Downshifts
  43. 7AT Problem (Not Software Related)
  44. Help rear differential leak?!?!?!????
  45. Ebay turbo kit opinions
  46. 350z manifold
  47. Help 350z intake manifold
  48. Mocal or Setrab
  49. Review Fuel pressure Gauge Kit
  50. Help low rpm oscillating metalic whine noise around 2400rpm
  51. Broke rear axle shaft..?
  52. Anyone switch back to OEM exhaust for sanity?
  53. MT synchros and lube
  54. Help SES code P2A00
  55. Gutting catalytic converters?
  56. G37 Grounding Kit ... Stillen G37x ?
  57. Drivetrain - Sport vs Non Sport
  58. G37X 7AT - manual DS mode
  59. Best RPM to shift in in the G Coupe
  60. Radiator cover/cooling plate
  61. "manual" vs "DS" mode in a 7at
  62. Help RPM Drop when at a stop...
  63. Constant exhaust cooling noise from under car after it reaches operating temp.
  64. Dealer Replaced Manual Transmission Under Warranty
  65. 6MT clutch sticks to the floor sometimes
  66. Ethanol free gasoline
  67. Cleaned throttle bodies, now...
  68. How to Swap and Replace Defective Automatic Floor Shifter?
  69. Transmission go BOOM! Infiniti says becoming common
  70. CAI in rain?
  71. G37x Major Transmission Problem HELP!
  72. Wanna transmission fix? Do this!!!
  73. 2013 G37 Journey - Paddle Shifters upgrade check
  74. UpRev Tune 09 G37s
  75. Check Engine Light Codes: P3634 & P0524
  76. Downshifting in the snow
  77. Who uses their Paddle Shifters?
  78. OEM or Aftermarket Motor+Transmission Mounts?
  79. New transmission under warranty.
  80. SES light question
  81. Won't start then tire pressure monitor light
  82. Help 6MT - Clutch Nightmares - 12,000 miles
  83. Exp. with simultaneous ABS/Slip/AWD Lights
  84. 7AT shift knob
  85. Engine not turning over
  86. Review My Uprev tune review
  87. critically low transmission oil!
  88. Help Video inside! Vehicle Speed Sensor Failure.
  89. Z1 Motorsports Clutch Concentric Slave Cylinder Elimination Kit
  90. How to use Drive Sports Mode
  91. G37x DS mode
  92. 08 G37 Engine swap into a 09 G37 Sedan
  93. Manual shifter cup part number?
  94. HKS Twin Power DLI
  95. Car jerked on the way to work, help!
  96. Question regarding CEL light and resetting ECU
  97. slight popping sound after hard acceleration
  98. Stuck Help Engine Won't Start??????
  99. How do I get 400 HP?
  100. 4.08s with stillen Sc
