PDA
View Full Version : Engine, Drivetrain & Forced-Induction
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 [42] 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62
  1. Help g37 bogging at low speeds
  2. so many software updates!
  3. Review ART pipe and Stillen UD pulley
  4. Coasting in the g37?
  5. HELP, SoCal Tunner/Dyno Needed!
  6. Coming from Nissan Z to Infiniti G
  7. High Flow cats and DYno
  8. 2nd Gear
  9. GTM Performance Engineering 1000HP MAF CALIBRATIONN -ANOTHER MILE STONE
  10. TWM short shifter
  11. Help QX56/Fx50 transmission swap?
  12. What is my car's drivetrain?
  13. So we never have to change the tranny fluid on 7SP AT.
  14. GTM G37x TT released
  15. STillen pulley's
  16. transmission
  17. Great News! 7spd/6mt
  18. Shifting
  19. tube-Breather !!
  20. g37 7sp shifting past redline
  21. knocking from motor..
  22. just snapped my serpentine belt FMl
  23. Please help identify this leaking seal
  24. Clutch oddity early in morning
  25. Help have problem in RPM
  26. Accidentally put wrong fuel in
  27. Getting my G37s coupe uprev tune this weekend. Need some advice
  28. Tranny Cooler Question
  29. Getting manual transmission replaced --warranty
  30. ecu re flash with stock exhaust
  31. GTM stage 1 tt kit
  32. NRG x2 catch can installed
  33. Starting the car
  34. Does Stillen SC work on g37x's ?
  35. RPM moves back and forth at cold starts?
  36. RMP Up But No Power
  37. Help Oil catch can
  38. 2008 G37S Auto - Reverse Gear Sluggish? Transmission Problem?
  39. Forged Performance: 2011 G37 IPL Bolt On Upgrades
  40. Different gas stations vs miles per gallon
  41. Stillen Supercharger Questions
  42. Help Low Power steering fluid at 20K Miles?
  43. Cooling System
  44. Adding Paddle Shifters to 2009 G37x?
  45. AWD and Gears swaps
  46. Help my warranty expired..thinking about getting forced induction..
  47. Invidia vs Invidia......
  48. GTM Performance Engineering StageII 600HP Supercharger kits lineup Press Release
  49. Help super charger wanted.
  50. Question about 3.69 gears in a 7 AT
  51. Crossmember/subframe cracked and need replacement
  52. Going Cobb Accessport...
  53. Need help with boost gauge install
  54. Thank God for Weekends, or I Got the R2C in
  55. eliminate lag?
  56. Stillen Gen 3 50 state CARB legal.
  57. can uprev software also tune the TCU/throttle on a 7at?
  58. Is there a 6speed manual transmission available for the G37x sedan?
  59. Help Shop to get my SC installed IN socal
  60. Redline
  61. The first GTM stage 2 supercharged sedan
  62. RPM Limiter?
  63. STILLEN Obtains 50-State Legal Status For 370Z/G37 Supercharger
  64. Need HELP!! What Intake should i get???
  65. weird sound when shifting into drive
  66. RPM drops while in neutral... 6mt problem
  67. What is this noise I'm hearing?
  68. Installing new lsd
  69. Anyone know where the VDC box is on a 08 g37s?
  70. Oil Change
  71. NEES HELP, time for transmission oil flush
  72. 4.08 gears and NST pulleys installed at Baker Tuning
  73. Loose Fuel Cap Warning Not Working?
  74. Help Losing pressure in Clutch
  75. Paddle Shifting 101 on the coupe
  76. GForce Chips
  77. Auto Tranny Cooler
  78. Anyone know of any Engine Mounts
  79. Help Check engine light gremlin from hell
  80. HELP with Paddle Shifters!!
  81. Engine noise after driving a while
  82. rear differentail swap
  83. Anyone have any experience/input with the Stillen/GTM Supercharger?!
  84. slight pinging under load?
  85. Upgrades for $900
  86. Automatic Shifting into Gears
  87. Fun with Cipher
  88. Opinion on running w/ CEL (tuned + bolted on)
  89. Got My New....
  90. Super charger needs a good tune in jersey
  91. Help Transmission Issue!
  92. PCV Valve
  93. Help Car wants to stall when AC is on and in traffic
  94. Takeda Install Pic
  95. R2C install help!
  96. Just ordered a set of pulleys
  97. Safe to launch at 3800 RPM??
  98. 08 6mt, 5th gear slight grind
  99. fuel pressure readings.
  100. car jerking
