- Clunking noise coming from rear while shifting (6MT sedan)
- Spark plug ngk 90174
- PCV delete benefits?
- Help Engine Prep for TT kit w/ 105k
- Diff Swap from 09-14 370 MT
- DIY G37 Valve Cover gasket and Spark Plug Tube Gasket change
- Clutch questions.
- Help Cold Start issue Stillen G37 Coupe
- Help Car sluggish, Scantool only reading 90% accelerator position at full thorottle
- Need radiator support
- Loud squealing noise ONLY when on reverse?
- 2009 7AT Sputtering at 2500rpm
- Replacing water pump
- Need help with custom exhaust
- zex wet shot instal
- Spark Plug tube oil leak
- Remove Rev Limiter?
- Starting Issues - 2010 G37x
- 6MT hesitation when accelerating under 3k rpms
- Motul Differential Oil for Front and Rear
- Engine rpm help
- for those with urethane diff bushings
- Whining Steering & CPO Warranty Question
- Can someone help me diagnose
- Coolant reservoir lower hose
- 2008 g37 Automatic differential question
- Rattling in park
- Intake valve cleaner / MAF sensor cleaner
- Anybody else every tried PCV Delete Kit?
- Help One more engine mod. Where is my money best spent?
- 2011 IPL Coupe feels slow
- Oil Change Intervals Question - Very Low Miles
- Help Cannot start car
- P0300 Return
- Overheating when idling
- PO710 covered under powertrain warranty
- Help Clunky Clutch Engagment
- Blown Engine, What's next?
- Titanium Hose Clamps
- who has turbo WITH automatic?
- SES light came back on after replacing oxygen sensor
- Header wrap for SRI?
- Problem Accelerating PLEASE HELP!
- AT to MT shift knob adaptor
- stuck in reverse
- Engine oil on spark plug
- Help Tapping/Rattling coming from engine bay - Sounds a bit different than the VVEL
- Clutch Slave Went - This is my setup
- Sprint Booster?
- Help Over Sensitive VDC / Slip
- Help 09 Sedan P2A00
- Help - Car making loud noise
- upper rad hose seeping coolant residue
- Squealing noise from front axle over 30mph?
- Looking for advice on a new clutch
- V8 swap?
- Oil Additives
- G37s clutch slipping high rpm only!
- random DS question.......
- Help VDC Off and Slip lights come on while driving
- Knocking noise.... VVEL question
- Ticking noise... vvel i think
- I smell your testpipes lmfao
- 4.083 Advice
- Long shot- anyone have the tool to remove rear differential bushing?
- Help Anyone have a rear diff subframe bushing puller?
- chek enhine p0732
- Do I need to retune with test pipes?
- bogging at low rpm
- 2010 coupe 6MT bogging at low rpm
- Help I need help! Pleaseeeeeeee
- 2008 G37S Coupe Rough Idle Plus Cel
- Stuck in drive but can still move the shifter
- Help ECU Replacement
- Lost Infiniti Engine Cover Emblem
- Help BERK HFC Questions
- Almost no throttle response
- My gear shifter just dropped an inch... What broke?
- Intermittent driveline vibration at highway speeds?
- Frozen boost and stillen exchanger together
- Transmission slipping after transmission fluid change.
- What to do - G37 Supercharge or TT set up.
- NEW Supercharger kit, NOT Stillen
- Clutch Slave cylinder replacement
- 7AT Parking Failure
- another limp mode question
- Help Black sludge on thermostat?
- IPL Engine comparison to normal g37
- G37s radiator replacement
- Ls2 or other v8 engine swap?
- G37S Coupe Clutch Died Today!
- AWD Motor Mount DIY?
- Installing Transgo Shift Kit
- Clutch
- Clutch Replacement
- '13 G37 Belt Squeal/Squeak with ticking during cold start
- Octane you use
- Please diagnose this noise
- Leaky Valve Gasket cover
- Transmission
