2013 G37x 7AT
Old Aug 26, 2018 | 11:48 PM
Debonaire_L's Avatar
Debonaire_L
2013 G37x 7AT
Hey Guys, Brooklyn Debonaire here, so i just bought my SECOND g37x sedan 7AT last month (Aug 24,18) with 60087 miles on her. fast forward to now, im driving from work, and under normal driving (1k-2500k rmp) shes fine, but i try to accelerate and boom, she does go anywhere anymore. She wasnt going past 60MPH but the RPMs were at 7k (we know this isnt adding up) The problem JUST started today. So what do you guys recommend? Most likely its a tranny issue. But see the attached video (if it helps). Could a transmission drain and refill be the solution? bad tranny? Need a new tranny? HELP HELP HELPPPPP
Old Aug 27, 2018 | 04:02 PM
DV8T1's Avatar
DV8T1
Well from experiencing an issue with programing with Transmission, I can tell you as long as your under 65k infiniti will cover it. I had to have some new coding set into my G37x (2013) 2 times as 2 new updates came thru. But I never experienced what you did, I just experienced a check engine light & down shifts where abrupt.
Good luck.
Old Aug 27, 2018 | 06:22 PM
Debonaire_L
Good luck.
okay thanks man. I too have a 2013. It was pretty weird. Now today, i took it to a reputable transmission shop, they said it was fine. I also drove it and the problem basically disappeared. My 2011 g37x with 62k miles never did it either. Hoping it was just a case of “im a machine ill mess up once” lmaoo. But when did these updates come out? What were they for? Andd should i take mine in to get updated?
Old Aug 27, 2018 | 07:07 PM
DV8T1's Avatar
DV8T1
The 1st update came out beginning of year march/april time frame. This last update came out beginning of summer. Its a quick thing. I made an appointment & had my car back in my driveway in under 3 hrs. As long as you get it in before 65k they will cover the updates free of charge. I heard after 65k its $95 to have them look at it & apply the update. But I'm sure with some good conversation it can be discounted.
Old Aug 27, 2018 | 08:47 PM
Debonaire_L
okay, ill set an appointment ASAP and ill give you an update. Did you notice any significant changes or any changes none the less? Im also going to get a tune up as well JUST TO MAKE SURE.
Old Aug 28, 2018 | 05:23 AM
DV8T1's Avatar
DV8T1
Shift where a lot smoother up/down, RPMS came down between shifts, quieter. Overall the shifts felt silky & quiet.
grisensko
Jun 9, 2015 01:14 PM
NiceG
Dec 31, 2014 07:49 AM
perdido34
Oct 5, 2014 10:41 AM
gizmo0034
Aug 26, 2014 01:39 PM
Texhex
May 16, 2013 10:34 PM
