Coolant leak?
Old Jun 2, 2018 | 12:32 PM
Steeltoe530's Avatar
Steeltoe530
Coolant leak?
So I checked fluids before a trip and the coolant reservoir was empty! Checked radiator and it was full.
Wife says o yeah the other day there was a blue puddle... I cleaned it up.
So I put new coolant in to check to see where the leak is. I see none. I drove it around and brought it up to temp. Park. No leak...
Park it back in drive way. No leak. Same level I filled it to. Stayed spot on temp while cruising.
I have never heard of coolant dumping from the plastic container and then having no leak after. Any thoughts?
Old Jun 2, 2018 | 01:15 PM
JSolo's Avatar
JSolo
Just say no!!!!!
Remove the lower belly shield and inspect the engine under side more closely. It's possible the leak is small enough that it would take some time before it becomes noticeable on the ground. Once you remove the lower shield it'll be obvious if coolant was/is there. It's a bunch of 10mm bolts and 3 or 4 rivet type push pins that hold it in place. Not difficult to remove at all but you will need to jack up the front of the car unless you're skin and bones.
Old Jun 2, 2018 | 05:03 PM
Steeltoe530
Thanks! I will take a look.
Old Jun 4, 2018 | 03:12 PM
Michael_in_DE's Avatar
Michael_in_DE
One guy just found a leak where the water pump meets the engine...$2k to fix he says.
Old Jun 4, 2018 | 03:36 PM
Steeltoe530
You gotta be kidding me!
Old Jun 4, 2018 | 04:09 PM
telcoman's Avatar
telcoman
Originally Posted by Steeltoe530
Any thoughts?
Do a pressure test
Telcoman
tite_tite
71
Mar 30, 2026 01:17 PM
tdoug
13
Jul 6, 2017 02:03 PM
jehu909
Jun 3, 2016 05:42 PM
tite_tite
Sep 25, 2015 10:21 PM
JSolo
General Tech Questions
Jul 9, 2015 01:57 PM
