- Help Show me your cam phasers
- 2009 G37 Limp mode w/ SES-No codes
- Help propeller shaft
- Help G37 intake sound / no pop and burble exhaust
- Help Transmission
- G37x auto low rpm vibration/performance
- Radiator loose at top
- Please help. What is causing leak?
- G37 coupe making hissing sound
- Loss of power after downshifting
- Help 2014 Q60s (G37) 6spd coupe knocking sound!!
- Help Engine noise while starting
- Intermitted stumble at stop light
- Vvel actuator motor
- Going to Specialty-Z tomorrow! Supercharger consultation :)
- Throttle blip problems when low rpm
- Idler pulley came off while driving
- Something rattling in engine
- TT kit with stock block, how much hp can it handle?
- Wont Rev past 3500 rpm
- potential exhaust leak?
- Bad sensor?
- Help Leaking Fuel G37
- 09 g37x(auto) is this normal transmission behavior? (High gear low speed)
- Crankshaft position sensor
- Car just stopped working when i was driving
- P0300 Misfire 1,3 and 5 Cylinders! New ECU Needed?
- Symptoms of a bad fuel damper? G37x
- Car starting and stopping
- G37 white smoke and leak
- Follow up on a brand new engine swap under warranty
- Radiator Hoses
- are Superchargers better for our cars? more common?
- Help HELP - Car not accelerating and not coding any issues
- G37 - Triptonic issue
- G37x knocking noise?
- G37x (auto) low rpms normal?
- Having new Differential Bushings Installed
- Losing coolant in 2012 G37 Sedan
- Z1 Motorsports 34 Row Setrab Oil Cooler Install
- Help G37 leaking from sensor
- Coolant question
- 09 g37 transmission flare or slipping?
- Help Coolant leak
- Real Performance Mods/Results...
- Clutch suggestions
- Car starts, shudders, and then shuts off with CEL
- VTC Gaskets
- G37x Service Engine Soon
- Automatic reliability on a g37xs coupe?
- Shop Towels sucked into intake
- Light Clutch Pedal After Driving on Freeway
- diy timing
- Code P0300
- $20 Diff Bushing Fix
- Transmission flare problem
- Clutch Sounds Like Chewbacca
- Transmission slipping on 2011 G37x sedan? need help
- Lag/throttle respond issue
- Auto Shifter issues
- Advice needed on Clutch, CSC, RJM
- Car randomly stalls for no apparent reason
- Definitive answer on the best stage 1 Clutch and Flywheel upgrade?
- Test Pipes or HFC?
- Runs like CRAP only in cold weather
- Is this normal for transmission? 09 g37x sedan auto
- Valvoline Asian Vehicle Coolant?
- Looking to install g37x paddle shifters
- My engine is making a squeaking sound
- Transmission coming apart?
- Engine noise under load when cold?
- 2012 Infiniti G37X differential fluid?
- G37 is jerking
- Coolant expansion tank
- Loss of acceleration and bog/stumble. Misfire?
- Possibly a transmission problem, need help
- Help Clutch pedal straight to the floor, leaking fluid
- G37 7AT warranty replacement
- Car start up hestiation/wont start
- Engine hesitation (stall) / no codes
- Driving in the snow and AWD cut-out
- Radiator/Condenser Fans Shot!
- Valve cover gaskets both with small drips
- Help MOVED: Engine oil leak - with pictures - need help fast
- noise coming from front of engine
- Engine Bay Dress-up
- G37s 6mt engine failure
- Transmission
- Radiator Fan Motor Replacement
- Help 2013 G37S 7AT Sedan 45k mi throwing Codes P0710 and C1109 and rough shifting
- Thermostat paired with auto transmission cooler?
- Black Friday/Cyber Monday 2017 - Deals Start Now!
- Engine/Drivetrain Popping When Cold-fix?
- Trans Fluid Cocktail?
- Clutch - gets stuck sometimes on '11 g37s coupe
- Should I replace valve covers on my 2011 G37?
- Why are the coups prone to rear sub frame bushing leaks?
- Motor Replacement Mechanic
- GTM TT on G37x
- Radiator Fans and Other Components
