- G37 coupe plenum vacuum leak at center screw
- Limp mode :( 2013 G37x sedan
- Engine Vibration
- any experiences with CSF racing radiators?
- 08 to 09-10 ecm change. Need a part #
- Metal noise when stepping on clutch pedal ('08 G37S)
- VVEL actuator motor repair
- new to the forum
- Engine Compatibility with 2008 G37 Coupe
- Clutch slave cylinder issues - clutch replacement in Frederick MD
- Stillen s/c kit
- Paddle Shifter Kit
- 2008 G37S Takes Several Pushes of Start Button to Fire the Engine
- Misfire need answer
- Firmware updates
- 7 speed at shutter at high way speed
- Trouble starting
- Help need advice from obd experts diagnosing a p0300
- Fuel air ratio problems: bank 1 lean , bank 2 rich.
- Help My baby is leaking coolant.
- Leaking trans cooler lines?
- What upgrades for rear differential
- Coolant Leak - Where's this location?
- Aftermarket transmission tune?
- 7AT delay
- Service Engine Soon
- rear timing gasket leak
- twin turbo setups that retain stock components? (A/C, wiper fluid, cat...)
- Q60 shift knob
- Help Is two oil coolers 2 much
- Clutch pedal has resistance coming back up
- Why does my car idle at 1100?
- 7A TRANSMISSION FAILURE (2012 G37xS w/32k miles)
- Squeaking noise while accelerating
- Happy Holidays! Sales Start Now!!
- Snow mode?
- Help Jerking, shutting off, and p010b
- OBD Scanner/Dongle Q&A Thread
- 3-4 gears cause engine to rev when shifting up
- Do I have to remove the intake manifold to take off the Valve cover???
- 6mt 2012 G37S 1st gear acceleration problems
- Whos rear turbo G is this?
- Running Lean
- Pop the Clutch
- Backfiring under hard acceleration
- Car starts, revs up, then stalls and shuts off
- engine noise
- P010B - limp mode - no cel
- I think my car is haunted
- Help! Car not starting lights stay on though
- Frozen Boost Heat Exchanger
- Red Oil light
- Help Loud Clunking
- Anyone here gut their cats?
- P 0171
- Help Stillen Gen 3 Intakes with a DEI reflect a Gold wrap
- Motor swap help!!!!!!
- How do you know when your motor mount is failing?
- vLSD in journey
- P-0455 & p-0456
- G37 after timing gasket replacement
- Experienced the 7AT hesitation first hand...
- Transfer case fluid - wrong fluid used.
- Black Friday/Cyber Monday 2016 Deals
- 2008 G37 limp mode code help
- Service engine soon... code P0171
- Matic K transmission fluid??
- Failed Emissions - no communication with OBD
- Help Please: Removed Cat Heat Sheild...What's This?
- Help Halp. pls.
- 2017 Pathfinder to get direct injection
- Help Oil burning smell when heavy throttle
- Cold start with no throttle response!
- PCV Location...
- Harsh shifts and pickup
- Performance Mods
- timing gasket failure - oil pressure sensor
- Vacuum clutch bleeders: ok or dangerous
- Largest capacity oil filter that fits
- Question regarding ATF service and AWD service from my dealer
- My car idles at 1100 RPM. Why??
- 09 g37 coupe running hot
- New member oil burning question
- DS mode on highway and slamming on breaks issue?
- Throttle Position Sensor/Throttle Body issue
- Nitrous question
- Need some insight on a few Problems
- Hard start & lagging issues, anyone?
- P0021 / P0524 Code Course of Action - Suggestions
- Help needed
- Help Stillen SC Overflow tank/Cap upgradable?
- Help g37x brain fart?
- Looks like 2013's arent immune from rear timing gasket failure
- Car won't accelerate past 3500 RPM, violent jerking
- Blue smoke
- MPG Reading after Stillen SC Upgrade
- What type of Gasoline for a 2013 G37 Sport Coupe?
- Chirping sound from under car
- Added a Z1 ported intake manifold to the car
