- Alternator making a loud noise
- Active cooling on Stillen SC
- Loose paddle shifter on new '13 coupe sport.
- 2013 G37 Auto Brake Torque Launching
- Any good shops in the OC?
- G37 Sedan Paddle shifters
- Clutch Bleeding Problem
- Help Can't get over 4th in DS mode
- Help New to modding, need your help
- R2C install
- Help Supercharger or Turbocharger for 7 speed auto transmission?
- Review EcuTek tune complete - solid gains on 2013 G37XS AWD Sedan
- GTM TT Stage 1 * Forged Internals * GTM Stage 4 Transmission * GTM Return Fuel *
- ENEOS 5W-30 - Upgraded Fully Synthetic Formulation!
- Oil change factoid
- Transmission reprogram problems?
- Bluetooth OB2
- Hypertech w/tune, throttle restriction off, intake tune - Reliability?
- Help HELP! GTM Driveshaft Install
- Software Update Question
- GTM TT Install
- Help GTM Driveshaft Woes
- OEM Clutch Rating?
- Stillen supercharge removal
- Help MT Shifter Linkage Boot
- Anyone running a surge tank with external pumps?
- Upgrades feel sluggish
- Where's the logic? (or am I not thinking right)?
- CSC location
- Oil Cooler
- tanabe or fi cbe
- Help NST is running a Group Buy, need more to make it happen!
- Transmission DS & M Problem :(
- Help Vibration at stop lights after HFC install
- service engine soon light
- Cracked my Axle - Aftermarket Options?
- Adding Shifter Paddles to 2009 G37 Journey: Are the plastic bits really needful?
- My 4.08 install...
- 370Z Tranny VS G37 Tranny
- Just got Tuned
- First Driveshaft Upgrade - GTM!
- Uninstalled my R2C Intakes for 09 G37x Coupe
- Uprev ProTune Expected Gains
- Link to latest TSB for 7AT?
- Help Servicing a Sealed 7AT Transmission Questions
- Shifting delay on G37x
- Ethanol Free Gas vs Gas with Ethanol
- G37S 5AT Torque Conveter Lock-up Low RPMS?
- Skyline 6 speed in AWD G
- GTM MHI Twin Turbo Kit Roll Call
- Clutch creaking?
- Did I screw up???
- Really? 7yr coolant change!
- How do I gain some more power without TT or SC?
- RWD vs AWD on the highway
- Broken Motor Mount
- Service Engine Soon light just came on - what is the dealer likely to say?
- Is a up rev tune worth it ??
- Review Does the g37 sedan need a strut bar?
- Dented Lower Oil Pan - 2012 G37x
- Help Differential fluids
- transmission fluid change
- Help Alternate filters for R2C Intake
- 08 Coupe rpm drops
- VLSD Swap?
- GTM Valvebody Upgrade
- Infinit's use of different drivetrains
- Grounding cables
- Regular or full synthetic oil change?
- Automatic G37 Sports Mode
- Best HFC setup
- Stillen vs Injen
- Service Engine Soon - Catalytic Converter
- Throttle body cleaning
- Installed my RJM Performance Clutch Pedal Assembly
- ECU reset
- Hydro-locked my car
- New Denso or NGK Plugs needed? Bit Slow Starting
- throttle problems
- How to make stock exhaust louder?
- Oil and Filter Change
- Anyone running two fuel pumps?
- New Z1 Headers are out!
- Need experienced opinion on HFC's
- Nissan 4.08 Gear Part No.
- k and n reusable oil filter this for real?
- 2012 Auto Transmission
- 1st Mod
- How much throttle lag is "normal"?
- Help HFC's
- 2008 G35XS Stillen Supercharged
- Jic Magic ypipe
- Help GTM turbo kit question
- Question about tuning
- Help Help finding the origin of a squeak
- Slight amount of play in radiator near top hose
- Motordyne M370 installed..along with a few other goodies
- Coolant Issue
- weird question
- engine power loss + low idle rpm
